I would love to know the answer to this question. I have an extra Galaxy s3 lying around that I could use for my car stereo with this DAC if it will work!
You could test your Galaxy S3 with your car head unit using one of three main types of Android car audio via USB described at the following link:
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/5490#post_10963953
I don't think your Pioneer car head unit is compliant with AOA 2.0 (the third type), because it is compliant with MirrorLink.
Also does anyone know if I can connect the GS3 via mini USB AND use mirrorlink to my head unit at the same time the sound is running through this DAC? Or would the head unit default to the sound signal from the mirrorlink connection automatically? I too am looking for a solution to get the best sound quality out of spotify in my car and it would be ideal if I could control spotify from my head unit. I just purchased a Pioneer AVH-X5700BHS which has mirrorlink technology and it should work with the GS3.
Thanks for the MirrorLink info! I didn't know it.
As far as I understand, MirrorLink is also the 4th type of Android car audio via USB.
music files > MirrorLink-certified music player running on MirrorLink-certified smartphone like Galaxy S3 > 48kHz PCM over RTP/UDP/IP >> regular USB cable >> MirrorLink-certified Pioneer AVH-X5700BHS car head unit: DAC > amp >> speakers
MirrorLink provides the technologies that connect consumers with smartphone applications in a car when driving.
"MirrorLink is a technology standard for controlling a nearby smartphone from the steering wheel or via dashboard buttons and screens. The technology leverages a vehicle’s controls and displays to give consumers access to their smartphone apps while driving, allowing them to be connected and responsible at the same time.
MirrorLink offers numerous benefits beyond replication of a mobile device screen on a vehicle’s dashboard. For example, MirrorLink specifies (1) use of BT or IP based audio streams to and from the mobile device, (2) advertisement, launch and termination of applications using UPnP, (3) mechanisms to exchange data between the car and the mobile device, e.g. location information and (4) the establishment of trust relationships and handling of application certificates."
http://www.mirrorlink.com/frequently-asked-questions
http://www.mirrorlink.com/consumers
https://cert.mirrorlink.com/ProductListing/
Apparently, Spotify is not yet a MirrorLink-certified app.
XDA modders have modified the MirrorLink service of some Samsung's flagship phones so that Spotify can be used (i.e. full mirroring).
http://forum.xda-developers.com/galaxy-s3/help/samsung-drivelink-dev-bounty-reached-t1837847/post46900253#post46900253
