Android phones and USB DACs
- Thread starter NZtechfreak
DanBa
- Nov 12, 2009
"[size=13.63636302947998px]Denon AH-D2000 modded with D5K cups, D7K cable, and Lawton Audio pads"![/size]
Then it's a D5K with Lawton pads, nice job!
DanBa
- Nov 12, 2009
Samsung Galaxy S III & affordable tiny Stoner Acoustics UD100:
http://forums.hardwarezone.com.sg/70075257-post210.html
http://www.head-fi.org/t/626632/tiny-dac-big-sound-impression-of-stoner-acoustics-ud100-vs-odac
http://stoneracoustics.blogspot.fr/
stock Galaxy S III > digital USB audio out >> UD100 >> Sennheiser IE80
Like the ODAC, the heart of the Stoner Acoustics UD100 is the 24-bit ESS Sabre conversion chip.
http://www.esstech.com/PDF/ES9023%20PB%20Rev%200.2aPB%20110117.pdf
avs234
- Sep 2, 2012
Samsung Galaxy S III > digital audio out >> USB OTG cable >> Epiphany Acoustics EHP-O2D (i.e. ODAC + O2 combo) >> Denon AH-D2000
Consider this. An android device (not even s3 or something), connecting it through an adb port and streaming those filles you have to have on your sd-card to any DACs or whaterver, and sending once again it's a dirty market program. Why cables, who cares?? Sorry, my personal selection emu0404. I had no trouble connecting my 0404, yes, no cables not known for me.
customNuts
- Mar 31, 2010
@danba So can you control (reduce) volume at all through the S3?
DanBa
- Nov 12, 2009
The UD100 is not mine.
As far as I understand, the adjustable output level feature of the ESS Sabre ES9023 chip is not implemented in the UD100 (and in the ODAC) unlike in the AudioQuest DragonFly.
The DragonFly allows Human Interface Device volume control from the player on the USB host (i.e. PC, Mac or Android device).
However without proper HID digital volume control, a player software can adjust the output level "by multiplying the each successive word in the original signal data stream by a coefficient that is less than one. For example, if the incoming signal is multiplied by a coefficient of 0.5, the output will be half of the original value. This corresponds with a volume reduction of 6 dB. In a binary system, a reduction of 6 dB is the same as shifting the signal towards the least significant bit by one bit", hence a theoretical loss of resolution.
Digital volume control:
http://www.wadia.com/technology/technicalpapers/Digital_Volume_Control_2.pdf
http://www.whatsbestforum.com/showthread.php?3813-Digital-Volume-control
Some people connect their UD100 directly to their headphones:
"yup, without amp.
i control the volume on winamp, although TS did mention there would be loss in quality but i seriously cant hear the difference.......still very good."
http://forum.lowyat.net/index.php?s=ada4a68cf5d770fbbb2e4a277fbb8c37&showtopic=2452730&st=140&p=54532789&#entry54532789
"sgs3 > UD100 > ath-ck100
volume level is sufficient, no amp required."
http://forum.lowyat.net/index.php?showtopic=2452730&st=160&p=54596977&#entry54596977
"but im currently using the UD100 without DAC, surprisingly it churned out the dark side of my Superlux HD330.......i can only imagine what will happen if I amp it"
http://forum.lowyat.net/index.php?showtopic=2452730&st=140&p=54532676&#entry54532676
ODAC directly connected to headphones:
"ODAC made all my Headamps Redundant !"
http://www.head-fi.org/t/621386/odac-made-all-my-headamps-redundant
"Well, I put sennheiser hd 800 directly on the ephifany edac.
I see the paradise.
Yes, in my s3 with neutron player I had to down the volune of 7-8 db, this, in teory, not very good, but I am very surprised about the super fantastic quality of sound out of my S3 with syhas kernel.
I am not crazy, please try this with high impedence headphone and share your experience."
http://www.head-fi.org/t/611778/brief-odac-impressions/1020#post_8715689
"yup, without amp.
I see the paradise.
DanBa
- Nov 12, 2009
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy S III:
stock Samsung Galaxy S III > digital USB audio out >> USB OTG cable (Micro-A plug inserted in the S III) >> standard USB DAC >> amp >> headphones
. AMB Labs Gamma2:
http://www.amb.org/audio/gamma2/
http://forum.xda-developers.com/showpost.php?p=27247705&postcount=279
. Asus Xonar U3 (USB DAC/amp):
http://www.asus.com/Multimedia/Audio_Cards/Xonar_U3/
http://mybroadband.co.za/vb/showthread.php/429589-Samsung-Galaxy-S3?s=1a313fae4795a9a7493a6ce0f677ca8e&p=8551119&viewfull=1#post8551119
. Behringer UCA202 (USB DAC/amp):
http://www.behringer.com/EN/Products/UCA202.aspx
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/240#post_8654226
. Behringer UCA222 (USB DAC/amp):
http://www.behringer.com/en/Products/UCA222.aspx
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/usb-audio-enabled-android-powered-samsung-galaxy-s-iii-12338/#post171651
. Beresford Caiman:
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-accessories/beresford-caiman-673787/review
. C-Media chipset-based sound card Dynamode 7 channel USB 2.0 (USB DAC/amp):
http://www.chinacomputerparts.com/d-p1140199199635616900-cables/
http://forum.xda-developers.com/showpost.php?p=27604946&postcount=449
. Cakewalk Sonar SPS 25:
https://www.cakewalk.com/support/kb/reader.aspx/2007013101
. Corsair HS1 Gaming headset (USB DAC/amp/headphones):
http://www.anandtech.com/show/3989/corsair-hs1-gaming-headset
http://forum.xda-developers.com/showthread.php?p=27238117#post27238117
. FiiO E7 (USB DAC/amp):
http://www.headfonia.com/fiio-e7-portable-dac/
http://www.androidnz.net/2012/07/galaxy-s-iii-real-user-review-part-2.html
. Furutech ADL Cruise (USB DAC/amp):
http://www.furutech.com/a2008/product2.asp?prodNo=399
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/585#post_8567838
. GoVibe DAC:
http://jaben.net/forums/index.php?topic=2824.0
http://forum.lowyat.net/index.php?showtopic=2440879&st=500&p=53317360&#entry53317360
. GoVibe Mini USB DAC:
http://www.jaben.com.au/collections/go-vibe/products/govibe-minidac
http://www.head-fi.org/t/614111/finally-digital-out-for-galaxy-siii/15#post_8525675
. GoVibe Petite (USB DAC/amp):
http://www.head-fi.org/t/290711/govibe-petite-dac-amp-appreciation-thread-pics-little-update
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs-how-to-increase-the-issues-priority-with-google/195#post_8552452
. HRT HeadStreamer (USB DAC/amp):
http://highresolutiontechnologies.com/headstreamer
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/750#post_8677483
. HRT Music Streamer II:
http://highresolutiontechnologies.com/music-streamer-ii
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/465#post_8534856
. HeadAmp Pico (USB DAC/amp): (Exynos-based S III connected to Pico via USB 2.0 hub)
http://www.headamp.com/pico/pico_dac_amp/index.htm
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/480#post_8539705
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/750#post_8688938
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/720#post_8638606
. HeadRoom Total BitHead (USB DAC/amp):
http://www.headphone.com/learning-center/bithead-faq.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs-how-to-increase-the-issues-priority-with-google/135#post_8527516
. HeadStage USB DAC cable:
http://www.inearmatters.net/2010/04/short-review-headstage-usb-dac-cable.html
http://www.headphiles.org/index.php/topic,4452.msg241979.html#msg241979
. HiFiMan Express HM-101:
http://www.head-fi.org/t/571330/hifiman-express-brand-and-hm-101-portable-usb-dac
http://forum.xda-developers.com/showpost.php?p=27284184&postcount=291
. iBasso D-Zero (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=73
http://neutronmp.com/forum/viewtopic.php?f=4&t=314&start=20#p1636
. iBasso D2 Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=30
http://www.head-fi.org/t/552014/pictures-of-your-portable-rig-part-xv/5535#post_8509186
. iBasso D2+ Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=42
. iBasso D5 (USB DAC/amp):
http://www.head-fi.org/t/556490/ibasso-d5-hj-yet-another-usb-dac-amp
http://www.head-fi.org/t/614111/finally-digital-out-for-galaxy-siii#post_8462693
. iBasso D12 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=63
http://forum.xda-developers.com/showpost.php?p=29069294&postcount=924
. iQube v2 (USB DAC/amp):
http://www.i-qube.nl/index.php?id=24
http://forum.xda-developers.com/showpost.php?s=6fe26080d10769d0f785157c83e74465&p=31207282&postcount=1268
. KingRex UD-01:
http://www.kingrex.co.uk/dac.html
https://www.facebook.com/headfonia/posts/352787358128700
. Leckerton UHA-6S MKII (USB DAC/amp):
http://www.leckertonaudio.com/products/uha-6s-mkii/
http://www.head-fi.org/t/602493/new-leckerton-uha-6s-mkii-portable-headphone-amplifier-announced-update-user-impressions-added-july-20th-2012/435#post_8698006
. Microsoft Philips Digital Sound System 80 (USB DAC/amp/speakers):
http://en.wikipedia.org/wiki/Digital_Sound_System_80
http://forum.xda-developers.com/showthread.php?t=1703218
. NuForce Icon HDP (USB DAC/preamp/amp):
http://www.nuforce.com/hp/products/iconhdp/index.php
. Objective DAC (ODAC):
http://epiphany-acoustics.co.uk/our-products/e-dac-24bit-miniature-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=46
http://www.headnhifi.com/index.php/shop/objective/odac
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/315#post_8707637
. ODAC+O2 (USB DAC/amp):
http://epiphany-acoustics.co.uk/our-products/ehp-o2d-miniature-desktop-headphone-amplifier-with-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=48
http://www.headnhifi.com/index.php/shop/objective/o2120527192048
http://www.facebook.com/permalink.php?story_fbid=410941392302962&id=164588276945555
. Ordnance .25 (USB DAC/amp):
http://jaben.net/forums/index.php?topic=9984.0
. RSA Predator (USB DAC/amp):
http://www.raysamuelsaudio.com/products/predator
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/150#post_8538933
. Stoner Acoustics UD100:
. Topping D1 Mark 2 (USB DAC/amp):
http://translate.googleusercontent.com/translate_c?hl=en&langpair=zh-TW%7Cen&rurl=translate.google.com&twu=1&u=http://www.tpdz.net/produce.asp%3Fid%3D25&usg=ALkJrhhte1Q6A1NnVWodszs9J4x85vGfDg
http://forum.xda-developers.com/showpost.php?p=28673076&postcount=871
. Topping TP30 (USB DAC/amp):
http://news.cnet.com/8300-5_3-0.html?keyword=Topping+TP-30
http://www.androidnz.net/2012/05/samsung-galaxy-s-iii-usb-audio.html
. VentureCraft Go-Dap X (USB DAC/amp):
http://venturecraft.jp/gadget_en/index.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/315#post_8708233
. xDuoo XP-1 (USB DAC/amp):
http://translate.google.fr/translate?hl=fr&sl=zh-CN&tl=en&u=http%3A%2F%2Fwww.xduoo.com%2Fxduoo%2FProductShow.asp%3FID%3D47
http://translate.google.fr/translate?tl=en&sl=zh-CN&u=http://www.erji.net/read.php%3Ftid%3D1320392%26page%3De&prev=/search%3Fq%3Dxduoo%2Busb%2Bdac%26hl%3Dfr%26biw%3D910%26bih%3D436%26prmd%3Dimvns&sa=X&ei=4GxdUKTrIaal0AXmr4HoDQ&sqi=2&ved=0CCcQ7gEwAA
. AMB Labs Gamma2:
. Beresford Caiman:
. GoVibe DAC:
. KingRex UD-01:
avs234
- Sep 2, 2012
You can't control it unless it recognises by the alsa driver.
Check up your .config and see what cards are supported, and what aren't. And if not, you have to add this module, as simple as that.
Nixon
- Jan 1, 2012
Galaxy Note running Paranoid Android 2.0 (Jellybean)> USB out cable> standard USB DAC >> amp >> headphones
Doesn't work with The Cambridge Audio Dacmagic Plus. Not sure though if that's because of the rom or that THe Dacmagic is incomaptible with android phones.
miandnan
- Jan 16, 2011
Is there any news on compatability with the asus xonar essence one? I am considering getting that dac for my computer and wonder if it would work with the phone
NZtechfreak
- Jan 19, 2012
Heh, I have one for my desktop but not tried it!
I suspect it won't work, since it requires driver installation on the PC and is not plug and play. Will let you know later today.
miandnan
- Jan 16, 2011
Cool I will keep my eyes on the lookout for your post
WiR3D
We intend to hurt him...quite a bit.
- Feb 2, 2012
Highly doubt it will work. wait... actually... if the STX works in linux, and the E1 works in linux, I'm sure it can work on android- mmmm
NZtechfreak
- Jan 19, 2012
As expected, the Xonar Essence One is not working with the S3. It does actually output sound, which surprised me, but it's utterly garbled.
Total: 17 (members: 0, guests: 17)
