Yep, the gain of the driver tube plays a big role in the Pendant. Also, there are lots more options than Raytheon and CBS in 12BH7 and I plan to try them all. Sylvania makes a black plate that is supposed to be killer, and the RCA black plate gets lots of love in others forums as well. Another one I am keen to try is the Westinghouse black plate. I like a certain sound, and will be pairing this 12BH7 up with others tubes (EL84 and EZ81), so who knows if you will like it in your amp with your preferences. I am just getting started with this tube type, and who knows where I will end up. All I know so far, is that the CBS 12BH7A D Getter sounds fantastic in the Pendant SE with my Atticus, when it's paired up with some Tungsram EL84 Foil O Getters and a Funkwerk Erfurt EZ81 Welded Plate Foil Disc Getter.I think what you're describing is relating to the gain of the tubes themselves. X has the most gain and is the most foward 'punchy' sounding of the bunch while AU is a bit lower. It's the same reason why a 6BL7 power tube is a lot more punchy and dynamic sounding than a lowly 6AS7. That doesn't explain why the BH7 does what it does though. It could be due to the larger heater current (it's weird though because the 6SN7 uses the same current as the BH7 but it's basically a larger 12AU tube).
I was actually waiting on your Raytheon 12BH7 review before purchasing some as often is the case with tubes another better one comes along when you find a different series, year, etc.
I imagine the size of the plates and other internal construction differences of the 12BH7, as well as the extra current is adding to the different experience compared to the other tubes.
