ZMF Pendant by Ampsandsound; impressions, tube-rolling, and general discussions
Dec 7, 2022 at 9:42 PM Post #1,801 of 2,619
Those look amazing! You might be hearing the difference between a burnt in pair and a fresh one. The Atrium seems to change a lot with burn in. Congrats!
Yes it does. I'll wait a while before I compare them.
Dec 7, 2022 at 9:45 PM Post #1,802 of 2,619
I wonder if that's just lack of burn in. My cherry seemed to have more bass, especially sub-bass when I first got it, and didn't really notice anything different when I got my Koa which I burned in at least 50 hours before spending much time with it.
Good to know. I'll burn them in for a while before trying to compare.
Dec 8, 2022 at 12:06 AM Post #1,803 of 2,619
Anybody here ever try to run the HE-1000 V2 off the Pendant? Apparently (and unexpectedly) they're poised to release a Stealth Magnets version of the V2, as distinct from the HE-1000SE. I've sold all my solid state gear, but I'm curious to know if the 90db planar will be an okay match with the Pendant SE.
Dec 8, 2022 at 7:55 AM Post #1,804 of 2,619
I run the LCD-5 on mine regularly. It’s an incredible pairing IMO. They are 90dB sensitivity at 14 ohms impedance. They do fine as long as I don’t go nutz with EQ and need a bunch of headroom. When I’m just using the Roon presets it’s 3-4 clicks louder than my VO
Dec 8, 2022 at 5:26 PM Post #1,805 of 2,619
Awesome. The synergy between Audeze and Ampsandsound gear is very real. I’ll be interested to see how the HEKV2 Stealth matches. Thanks!
Now time to test the Tungsram 12AU7 dual foil disk getters…
Dec 8, 2022 at 5:38 PM Post #1,806 of 2,619
What year are those? They don’t look like welded plates from that photo
The synergy is real with A&S and Audeze but I’ll be keeping my V550 Pro. The Pendant SE handles them better than I had expected but there’s a magic with Violectric and LCD-5 (esp speed and transients) that can’t be beat. Plus it’s got all the headroom in the world for EQ
Current status. I’ve listened to both amps back to back today with my LCD-5 (with a pigtail to easily swap between)
Dec 8, 2022 at 5:56 PM Post #1,807 of 2,619
Not sure what year, but he said it was from the early-mid 50's. Just to be clear, the power tubes are Amperex EL84's (not welded plates), but I was referring to the Tungsram in the pre-amp socket. It was the only angle I could get a clear picture of the label with :sweat_smile: I'm not sure at all if has welded plates, but I'm loving the sound so far! How would I be able to identify if they have welded plates?
Dec 8, 2022 at 6:05 PM Post #1,808 of 2,619
Ahh that makes sense. I forgot you got an ECC82 from Brent. I thought you were referring to the EL84’s
Welded plates look like this (you can see the distinguishing weld marks inside the tube)
Dec 9, 2022 at 9:30 PM Post #1,809 of 2,619
More preamp tubes! A pair of ECC82 RFT foil getters just came today from Ukraine.
All that’s left is to pick up a couple good rectifiers (using the one included in the “vintage” set from ZMF) and I’ll be in a very stable and happy place with my Pendant.
Dec 9, 2022 at 10:11 PM Post #1,810 of 2,619
I have a couple of those. I thought they were worth the wait. I think you'll like them. "I’ll be in a very stable and happy place with my Pendant" , good luck with that! I thought that at least 5 times LOL
Dec 9, 2022 at 11:04 PM Post #1,811 of 2,619
“I’ll be in a very stable and happy place with my Pendant" , good luck with that! I thought that at least 5 times LOL
You’re right. Until I wrangle up a G73-R there will be no rest 🤣
Dec 10, 2022 at 10:51 PM Post #1,812 of 2,619
Ohhh man you were right! The RFT foil getters pairs REALLY well with the Auteur Classic in particular. I like it more than my Telefunken ECC82 smooth plates. It doesn't have as much bass bloom or smoothness, but more impact with just as much soundstage. Tone is no quite on the same level, but pretty close. Really beautifully textured, tight presentation. For a tube that costs $25, that's incredible.
Dec 11, 2022 at 1:44 AM Post #1,813 of 2,619
Hi, just wondering everyone's thoughts on which headphone I should get to complement my Atriums and VC on the original Pendant. I've narrowed my search to the Utopia, LCD-5 and Susvara. Of the 3 I've only heard the Utopia's and that was years ago. I was floored by the resolution, depth characteristics it was presenting and it's airy high frequencies. With that said, I'm more looking for the headphone that will play well with my Pendant/Qutest as I'm sure all 3 of these are outstanding on the right setup. If I could audition all 3 on my setup I would do that, but I'm nowhere close to a location that could provide that.
Thanks for everyone's thoughts!
