ZiShan DSDs
Upgraded model of ZiShan DSD audio player, available in 2 different versions:
1. ZiShan DSDs Dual AK4497EQ, featuring;
- PCM playback: up to 32bit/384kHz
- DSD playback: native DSD up to 11.2MHz (256)
- DAC: AK4497EQ*2
- LPF: OP275*2 (Soldered)
- AMP: LM4562 (Rollable)
- Output power: 400mW @32Ω
- MCU: STM32F7
- CLPD: Altera Max II
- Crystal oscillator: Dual; @45.1584-MHz ,49.1520-MHz
- PO: 3.5mm
- BO: 2.5mm AK
- LO: 3.5mm
- Coaxial: 3.5mm TS
- Display: 2.4" WQVGA
- Operation method: 5 physical buttons
- EQ: 180 preset, custom equalizer available
- Sound filter, DSD frequency cutoff, sound quality, sleep timer options, etc are available
- USB port: Type-C (Combined charging and USB DAC ports)
- Relay: Axicom IMO 1 3VDC (PO only)
- USB DAC: fixed 16bit/48kHz
- SD Card expansion: 256GB (FAT32 required)
- Battery: 3.8V 3000mAh
- Body dimensions: 80mm x 58mm x 24mm (H x W x T)
DSDs AK4497:
~ Inside
~ Block diagram
2. ZiShan DSDs Single AK4499EQ, featuring;
- DSD playback: native DSD up to 1bit/11.2MHz (256)
- DAC: AK4499EQ
- I/V: Pro version; AD8620*4 LPF (Soldered) / Normal version; OP275*4 (Soldered)
- LPF: Pro version: MUSES02 AMP (Rollable) / Normal version: LM4562 (Rollable)
- AMP: BUF634*2 (Soldered)
- MCU: STM32F7
- PO: 3.5mm
- BO: 2.5mm AK (note: when you use the 2.5mm balanced port, you must connect an amplifier or a balanced pre-amplifier.)
- LO: 3.5mm
- Coaxial: 3.5mm TS
- Operation method: 5 physical press buttons
DSDs AK4499EQ:
~ Inside
~ Block diagram
(Couldn't find the block diagram for the 4499 so i decided to make one by my own.)
Gallery:
Front & rear | Top & bottom | What you'll get | Quick start guide |
Playback support | ZiShan player comparison | Sound filters | Sound quality setting |
(Open links down below to see more information.)
Links:
∆ You can get DSDs AK4497 here on AE:
https://www.aliexpress.com/item/4000785853010.html
∆ You can get DSDs AK4499 here on AE:
https://www.aliexpress.com/item/4000786175396.html
∆ Firmwares:
https://pan.baidu.com/s/1vFVaDb6TuRP6JdYJD0xKfA
Password: 0brr
Updates:
None so far.
NOTE:
If your DSDs is draining a lot of battery and exhibiting a lot of heat, you might want to turn off the "Turbo" DAC setting. That way, your DSDs will have an extended battery life and less heat.
P.S. I know the DSDs is kinda "cold" now, but due to requests and the fact that the DSDs is a different line up from the old DSD, so I decided to make it happen. And there you go, i hope this thread can be useful.
Stay healthy,
God bless
