OK - had another 2 hours with these and they aren't improving. I've also measured them (and remeasured them) so that I know what I'm getting is consistent.
Before I measured them - this is my findings (after running them through my usual tracks for reviewing) - so I know these tracks incredibly well.
- Sub-bass = OK, there is a bit of rumble there, and its not too overdone.
- Mid-bass = overdone, and is a real part of the problem. Its not just a hump, relative to the mid-range its a mountain. Bit it doesn't sound like a typical hump because it's not centered around 100-200 Hz so its not manifested as impact. Its hard to describe.
- Mids - distant, sucked out, muddy, lost. Worst mid-range I've heard for a long, long time. It's not just slightly dissonant - it really is awful.
- Lower treble - it's "OK" - but you don't notice it because the mids and bass just aren't coherent
BTW - I've tried these with my iPhone 5S, X5ii, X3ii and with the E17K. All the Fiio's are low impedance and the E17K is basically dead flat so any issue is coming from the earphone.
And here is the problem:
(Usual disclaimer - The graphs below are generated using the Vibro Veritas coupler and ARTA software. I must stress that they aren’t calibrated to IEC measurement standards, but the raw data I’m getting has been very consistent, and is actually not too far away from the raw data measured by other systems except for above 4-5 kHz where it shows significantly lower than measurements performed on a properly calibrated rig. So when reading the graphs, don’t take them as gospel – or at least remember that the area above 4-5 kHz will likely be significantly higher.)
Left and right channel matching - which isn't too bad, so I don't think this is a QC issue. For this to be a driver issue, both channels would need to be affected equally (unlikely). Also - assuming the failure of a pair or BAs - there would be far more cut out of the frequency chart I think.
And as you can see - massive mid-bass which bleeds all over the mid-range, sucked out and muddy mid-range, and no cohesion between lower and upper mids.
In the Fidue Sirius thread, someone suggested they were being overhyped, and also I had someone also mentioned in my FLC8S review that the QT5 was superior - so lets look at the Sirius next to the QT5.
Sirius has a bass vent on the inside. This is what it looks like uncovered - and below is what it looks like covered:
I think the reality with the Sirius lies somewhere in between - and maybe even closer to the flatter graph. Anyway - the bass on the Sirius is in perfect proportion, extends well, and the mid-range has a nice bump. Tonally it is very coherent, and natural sounding. Contrast that to the QT5 and it shows the QT5's issues even more.
I'll leave you with one more - the MEE P1 - which I'll be writing up soon. It's a single dynamic, only $200, and in every aspect - build, cable, accessories, and most importantly sonics - there is daylight between it and the QT5. For this graph I didn't volume match at 1 kHz because it doesn't show the true picture. Instead I matched at where the natural peaks are - and it is this graph which should show everyone just how horribly tuned this particular pair of QT5s is.
I'll photograph these tomorrow - just so that I have a fair record of them - but at this stage I'm not reviewing them. It would give me no pleasure, and I can see nothing constructive in doing it. The only thing that worries me is that both reviews on the QT5 are very positive. It could be that this unit is defective - and I'd suspect something is amiss because I can't see either bhazard or FUYU rating this particular pair as anything but a 1 or 2. It worries me that if Zhiyin's QC is very inconsistent (and honestly after viewing the cable and listening to them - I'd really question their QC standards), then based on those two reviews - people run the risk of buying lemons.
I want to re-iterate that I am in no way saying that these two guys have written dishonest reviews - as I suspect their units sound a lot different to this one. I'm just saying that I'm not too sure how to fix the current situation - and to be honest, I don't want to waste hours writing these up.
Many thanks to Audio DHD for sending them down. You'll have them back just after the weekend.
