The good ol' Pareto Principle. Especially at this price-point, such errors aren't really suprising.
ZhiYin QT5 4BA + 1DD Impressions Thread
- Thread starter bhazard
hellfire8888
- Oct 12, 2012
actually such QC issue is really not acceptable...considering the volume they manufacture each month..
harpo1
- Dec 1, 2014
What are you talking about? This is the first reported case of any QC issue. If they only sold 100 this would be a 1% failure rate. Be real here people this is completely acceptable. **** happens within every industry. No company has 0% failure rate. The big question is how will they handle this situation.
kimD
- Feb 5, 2016
They should reduce the weight and fine tune nozzle tube size.
SeeSax
If it was bought from Ali, I can tell you exactly how they will handle the situation. They will make you ship it back on your own dime (and try to get you to pay for Express mail since it can be reliably tracked) and wait two weeks for a replacement. They may reimburse you for the shipping once it's determined that it's defective though.
-Collin-
alex1577
- Jul 2, 2015
Man, seeing those drivers split apart makes me consider the dqsm even more, but its a minor issue really. Can anyone comment on how comfortable these are with the cable hanging straight down? I take it the cable would be quite heavy. Also, anyone with small ears having any trouble getting a good fit?
hellfire8888
- Oct 12, 2012
each IEM is not mass produce and was order to build. When u handmade each IEM u should have less margin or error compare to mass produce.
And for the record, this is not the first reported QC issue...the sound quality or signature will have a little bit of variance and right now there are huge different among various QT5 owners. Is like buying a Sennheiser headphone for its sound signature only to realized you get a Beyerdynamic sound signature and to make matter worst..it is a hit and miss depending on your luck on which sound signature you will get.
Next is you need to differentiate between acceptable failure rate and obvious failure rate that is not acceptable. When you manufacture a car, if the wheel is out of alignment, that is acceptable failure rate..but when the car wheel just fall off, that is not an acceptable failure rate and should not have left the factory.
To me there is no other way than to do a proper damage recovery by replacing all the faulty units out there without crazy shipping cost on the buyer expense and issue a statement on what actually has gone wrong.
How many IEM or headphone in your life that you have bought that can change it sound signature overnight from veil to bright? There are hundreds of IEM out there, name me one that exhibit this bizarre phenomenal incident.
Paulus XII
Formerly known as FW214b
Mines never changed anything with the exception of the "normal", somewhat expected subtle burn-in changes.
harpo1
- Dec 1, 2014
If it was bought from Jim at HCK, I can tell you exactly how they will handle the situation. They will make you ship it back on your own dime (and try to get you to pay for Express mail since it can be reliably tracked) and wait two weeks for a replacement.
-Collin-
I understand his position with your situation. You're not even sure there is a problem with your QT5. This situation there is an obvious problem maybe he'll handle it differently.
SeeSax
I think and hope you're right. This time we can skip the step of sending to bhazard lol
harpo1
- Dec 1, 2014
How do you know there are huge differences in the sound without having several in hand to test? We all hear things differently.
hellfire8888
- Oct 12, 2012
that is why i consider this as a QC issue,
the argument is vice versa, how do you confirm there is no huge difference assuming everyone hearing is still normal and is not damage due any accident or due to old age?
harpo1
- Dec 1, 2014
Because what one person perceives as bright another might not. The same is true for warm sounding iem's and hp's. The only true way to tell is to sample several pairs.
Bribo
- Jan 11, 2016
Ok all QA issues aside, OOTB I have to say that these puppies sound pretty amazing, the sound actually seems to be coming from outside my head in all directions. I think this is due to them being open. If i cover the holes the 3D effect disappears.
Trying2Learn
- Jan 28, 2015
He's found the secret! For a truly open and air soundstage, ya gotta open up your iems! Looks like it was intentional on the other side prior to shippingOk all QA issues aside, OOTB I have to say that these puppies sound pretty amazing, the sound actually seems to be coming from outside my head in all directions. I think this is due to them being open. If i cover the holes the 3D effect disappears.
