El Condor
- Oct 30, 2006
I seriously don't know since I don't have a Corda Headfive nor Sennheiser headphones, nor your ears and mind
. The best way to know is to try it out yourself. You can then spread the good (or bad) news around. All it will cost you is 2 very small RCA cables.
Using the Zhaolu as a preamp will simply send a stronger signal to your Corda Headfive to work with.
Originally Posted by Mher6 /img/forum/go_quote.gif To clarify, what I really wanted to know is what are the benefits to using the zhaolu as a preamp (phone out vs analog out). Should it/will it sound better if I use the zhaolu as a preamp? Or would you suggest using only my H5 to control the volume. |
