- Mar 20, 2013
So the main question is actually how this Ifi compares to a VP29
Honestly I haven o idea
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I know I'm late to the party on this thread but can anyone compare the ifi to the project phono box S2? I've got the S2 on order but I've had an email to say there are problems with the supplier and it may not be ready to ship for a month. I've been suggested the ifi as a readily available alternative instead. I'm using a Beogram 1700 with an MMC20EN cartridge, my concern is that 36db of gain on the MM setting will be too low, 48db on the high MC too high. Never really been able to get my head around voltages and what's appropriate for any given setup.
You have effectively 4 selectable gain settings:
And here is the specs from the box:
For reference, the MM setting worked fine on my OM-10 cartridge/stylus. The output of the OM-10 is 4mV at 1000 Hz, 5cm/sec. If you can find the spec for your cartridge for the same frequency and speed, then I guess it should work. If your cartridge outputs a lower voltage then you can try the first MC setting. I couldn't find specs for 5cm/sec for your cartridge. From what I understand, you have a lot of leeway when it comes to cartridge outputs.
Does your record player sound fine when connected directly to an integrated amplifier? Did you check that the earth wire is connected securely? What do you hear when you are NOT playing a record? Do you still hear noise?I just bought Zen Phono and attached it to my LP system which is: Technics SL1200 MK5, Ortofon 2M Blue, and active speaker Klipsch R-51PM. I set the gain on '1' which is for moving magnet as per my cartridge. But the sound was so awful, there are so many loud static noise and pop sound from my speaker. Is there anything I done wrong? I already activated the Subsonic Filter, but the result remain the same.
Yes, it's sound fine when I connect it directly to an active speaker. The setups I used are Technics SL1200 mk5 with ortofon 2m blue cartridge and klipsch R51PM speakers.Does your record player sound fine when connected directly to an integrated amplifier? Did you check that the earth wire is connected securely? What do you hear when you are NOT playing a record? Do you still hear noise?
Okay, I've just looked up your speakers and they do have a phono input (RIAA) via switched LINE/PHONE input. Could you carry out the following check please?Yes, it's sound fine when I connect it directly to an active speaker. The setups I used are Technics SL1200 mk5 with ortofon 2m blue cartridge and klipsch R51PM speakers.
I then just added Zen Phono at the middle of chain. There's nothing when I just plug it and not playing it.
When I turned on the subsonic filter, there are popping noise, and when the record started to play, the noises intensifies.
Thank you for the quick response, I will try it and update the status to you.Okay, I've just looked up your speakers and they do have a phono input (RIAA) via switched LINE/PHONE input. Could you carry out the following check please?
1. Check that your record player left, right and ground connections are connected to the correct terminals on the Zen Phono
2. Check that the LINE OUT from the Zen Phono is connected to your active speakers using a stereo RCA cable
3. Check that the SWITCH on your active speakers is set to LINE INPUT mode (as you are no longer using PHONO IN on your active speakers). The output from the Zen Phono is a line level output and requires a line level input on your amp/active speakers. Make sure you turn the volume right down before switching anything on!
if the zen phono has such a clean internal power supply filtering system is it pointless to feed it something like ipower x?
A good external PSU is always something worth taking into consideration![]()
Sneaky...
