I am actually planning on using that plug to but I am not 100% on how to solder it. It doesn't look like any of the plugs I have used in the past. (crappy ratshack 1/8).
The solder is the seal. If you make the joint properly, it will last longer than the headphones themselves, unless you use a solder type prone to tin whiskers.
you can use a pair of needle nose pliers to hold the wire right at the edge of how far you want to remove the enamel. The pliers will act as a heat sink, and prevent excess enamel from being burned (melted) off.
