Themilkman46290
Hey guys, I have the chance to buy an A1 for about $145, is it still a good buy? How does it compare to others? I don't plan on using Bluetooth or tidal. I have mainly flacs.
Hi, where did you find it? I would be interested in buying it just to try YinLvMei sound for that priceHey guys, I have the chance to buy an A1 for about $145, is it still a good buy? How does it compare to others? I don't plan on using Bluetooth or tidal. I have mainly flacs.
I've been using A1 for about two years and sold it just a couple days ago The last time (a week ago) I checked the battery life I got approximately 8 hours 30 minutes of FLAC (mostly 16 bit 44.1 kHz material) playback on one charge. Yes, the Android version installed on A1 is comparatively old (5.1), but its contribution to the battery consumption is far smaller than that of the DAC and all the analog circuitry of A1. So the Android version is not the point. The sound is cool on A1, you will hardly find anything close to A1 SQ-wise among modern DAPs of similar price or even those priced at about $600.Hey guys, I have the chance to buy an A1 for about $145, is it still a good buy? How does it compare to others? I don't plan on using Bluetooth or tidal. I have mainly flacs.
Though even "old" 4497 DAC chip supports DSD 512 in hardware (pretty much a useless feature, at least in portable gear, as for me), its implementation allowed for up to DSD 256 native playback only (which is also a rare case for the recordings, on which one really can hear a difference between DSD 64-128 and DSD 256). This was mostly due to the SA 9227 USB receiver chip that YinLvMei had been using, I presume. Now, in S3 lite and their new W0 DAP built on the same AK4462 DAC (using the CT7601 USB receiver), they switched to another USB chip, which is capable of DSD 512 output.Just found a new product on YinLvMei website, the S3 lite. It has a new AK4462, which supports DSD512 and also has an output power of up to 200mW.
AND it's only 5cm long (50mmX22mmX11mm)
Well, I did not have a chance to try A1SS (and doubt that anyone outside China has it), but the digital part of A1SS is the same as of A1S and A1, if i get it right. Thus, the A1 inherent bugs you refer to plague the A1SS as well.Isn’t the A1 ridden with crazy bugs according to Chinese sources? Has anyone else tried the A1SS (silver chassis)? I read that it’s details betters the A2 and is tuned with more focus from mids to bass. It sounds more forceful than the A2, if I had to directly translate. Comparatively the A2 is tuned with more clarity from mid to upper frequencies and is looser sounding
However, I find A2 sounding better than A1 for me and doubt that getting A1SS is worth it. The lows on A2 are by no means loose, they are very well controlled and go deeper compared to A1
Might be so. However, I read on some forum or in some chat that A1S is "warmer" (and probably with little punchier bass too) than A1 and A2. Again, in terms of usability I'd prefer A2 as I find the vertical volume knob (even more so because of the protective arch on A1S) of A1 and A1S less convenient than that of A2.On this chat section it seems to have two users praising that the A1SS sounds better than the A2, with one comment saying that A1SS has better resolution capabilities, and the more powerful one, A2 is more laid back on comparison (if that is what I can understand). Also both have different tuning, with more clarity on upper registers of A2
I think that the A1SS is an upgraded A1S with limited production, hence pricier.
How does B2 compare to M400 plus? Is the difference in SQ too big?Sorry to hear that. I've been enjoying the B2 for 2+ months. Excellent sound, so much so i took the plunge and just bought the M400 plus, delivery in progress. I experienced BT sound drop outs too when using USB Audio Player Pro. No dropouts at all when using Tidal native app.
It would be hard to quantify the difference between the two, as this is subjective. To my ears, i can definitely hear improvements with M400plus, mainly more open and wider soundstage, and tighter bass.How does B2 compare to M400 plus? Is the difference in SQ too big?
