MisterX
- Dec 30, 2002
Set it as the default playback device.
delete and learn to read next page before posting...
Just to be clear, if I solder J1 through J5 on the y2 it will make the y1 work...... without any other chips on y2?
Originally Posted by BobSaysHi /img/forum/go_quote.gif
1.) Since I am using a plastic container would I need to ground anything? Should I just man up and buy a case?
2.) I only want one input, is it possible to skip the "NKK G13JVCF bicolor illuminated toggle switch"? From what I understand that switch is used to toggle the inputs. Would I need to solder jumpers to my board to skip this switch?
3.) I've decided to build the σ24 and σ25 kits as well. I think all of the Molex input and output terminals have the wrong pictures in the Mouser Website. Is that correct? I can just skip these and solder directly to the board right?
4.) Can I just cut an existing power cord and use that for the input?
5.) I just noticed that there weren't any fuses installed. Can I add fuses?
6.) Why can't the "Pulse BV030-7151.0 1.5VA EI-30" be used on the both the y1 and y2?
