K3cT
- Apr 1, 2007
Sorry for bringing up a rather old post but I'm just curious, is there any problem driving headphones straight with the WM8501 and its higher output voltage?
Originally Posted by amb /img/forum/go_quote.gif It is not surprising that the volume might be very loud with sensitive, low impedance 'phones due to the strong output. If the software volume control doesn't give you enough control range, then you should either use an impedance adapter for your headphones, or better yet, a low-gain headphone amp with a proper analog volume control. Btw, those of you who want to use a y1 to drive low impedance headphones directly should use the WM8759 DAC chip rather than WM8501. The two are identical except the former has lower output voltage. |
