amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
Yes, this one would work and the pin-outs are the same as the TOTX147PL, but the mounting holes on the board for this one are not compatible. This one doesn't use the snap-in plastic pegs and the two unused pins the TOTX unit has, but has two side-mounting tabs for which there are no holes on the PCB.
I'll check into the availability situation on the TOTX147PL (and TORX147PL) and report back. Meanwhile, those who are building γ1 USB-to-S/PDIF and full++ configurations might want to get together and make a combined order from Newark to split the surcharge.
It's hard to figure out just what's going on in your setup, but this is what I would do:
- If you're using the +15V from the CK²III board and dropping it down to 5V with the 7805 regulator, then the 7805's ground should be tied directly to the CK²III's star ground, and run the +5V output to the γ1.
- Run one ground wire from the γ1 to the CK²III star ground (it shouldn't matter where you connect this on the γ1, as long as it's securely tied to its ground plane (the ground pad for the output jack is a good place for this).
- Isolate the USB connector's shell ground from the case, or you might run into a ground loop situation even if you use a ground loop breaker.
Originally Posted by fishski13 /img/forum/go_quote.gif i'm putting together a BOM for USB-to-S/PDIF only option. i wonder if this would work?: Digi-Key - 425-2605-5-ND (Sharp Microelectronics - GP1FMV31TK0F) |
back to my ground problem, there's a reduction in the hum when both the optical and coaxial outputs from the Oppo are connected - optical to the y-1 and coaxial to my Benckmark DAC1. the switching transients were related to the fact that with the Pioneer cdp connected (i was trying to find out if it was an issue with the Oppo), it happened to be plugged into a different outlet on a different house AC circuit. no issues when plugged into the same outlet/power strip. i'm wondering if the ground problem is caused by the fact that my LM7805 ground reference is "upstream" from the CK2III PS ground and tied in at the PS ground before going to star ground? i'll try a ground loop breaker before i rip apart the PS board. |
