germanium
Your assumption is probably correct however I always measure it anyway both before & after removal of the caps. Measure at the input side of the caps before removal.
The caps only effect the line out. The headphone amp is already D.C. coupled, however the headphone amp has more D.C offset than the lineout opamp does & that can be a problem for high gain D.C. amplifiers so the line out is still the best option for driving D.C. coupled amps. This remains true even with the caps removed assuming that the D.C. offset is similar to what I read on mine.
Originally Posted by johnzz4 /img/forum/go_quote.gif Germanium, I'm guessing that the DC offset of the ST should be very close to the STX you tested. Safe assumption? If so, I will be bypassing caps since I can't go back to the line outs with the lesser soundstage and detail. Right now, I'm favoring the headphones by sending the headphone out to my headphone amp, and the line out is feeding my monitors... I would like my monitors to have the same quality signal that I have going to the headphones. Let me know your best guess on the DC offset of the ST in comparison to the STX and I'll get soldering. |
