ROBSCIX
- Aug 25, 2005
If the Little dot accepts normal line level inputs then you should be fine going from the STX line out to the Little Dot. Just turn up the master volume on the STX. This is for line out... Driving a head amp from another head amp is not such a good idea.
Originally Posted by jonka /img/forum/go_quote.gif I've been using the Asus Xonar Essence STX with my HD650's for a while, and picked up the Little Dot MKIII last night. Not really able to give any impressions yet, as I've been struggling a bit so far. Using the line out's on my Xonar to power the Little Dot isn't working too well, I'm having to use close 100 volume on the Little Dot to get sufficient listening volume. Switched to using the HP out on the Xonar to feed the Little Dot now, that seems to work alot better, sufficient volume already at 50 volume now. Also there is a TON of background noise originating from my Little Dot - I'll try using higher grade cables, as I'm using el cheapo unshielded ones now. |
