Originally Posted by qusp /img/forum/go_quote.gif
show me another one that's body IS the dielectric...
You don't generally see plastic bodied XLRs because the body is typically used as an extension of the chassis in order to provide shielding.
...but these are MUCH smaller run than any of those connectors, from a small company, using expensive materials and processes (ie CNC) thus the price difference. |
CNC isn't an expensive process.
Manual machining is an expensive process.
all I said initially was to match the materials in the cable and the format of the cable ie 2 separate copper cables; 2 separate copper connectors (on my dac), 2 separate copper XLRs...makes sense really, well it does to me anyway. |
That's fine from a purely philosophical standpoint.
and all I said about neutrik was that I had a bad experience recently that put me off them, which of course he would not accept because he is the 4 pin champion |
What you said was "the plating is crappy and thin, the silver corrodes down to the underneath on the silver versions sometimes before you even receive them."
By all accounts, it wasn't crappy plating that was corroded down to the base metal but was was some simple tarnishing which could just as well have happened with anything else that used silver pins.
well actually its not just for silver pins, generally the only ones I have seen with silver pins were machined out of solid PEEK as well |
Well, their pricing doesn't indicate that the silver pin version is made from PEEK. But even at that, a 1" x 3" PEEK rod from McMaster Carr is $25. So how does that and a few dollars worth of silver add over $2,000 to the price?
again, you simply dont seem to get this stuff of accumulative measures, that is avoiding one problem when you can, your process really doesnt bode that well for a good result if you keep on ignoring little problems because there is another one to distract you. |
I get it just fine. I'm just not singularly obsessed with it to the point of being neurotic. I prefer to take a step or two back and look at things in context and assess what they amount to at the end of the day.
You're worried about the difference in resistance between an XLR pin made of copper and an XLR pin made of brass.
Ok.
So tell me, what gauge wire are you using in the cables that you're using the BAXLR's to terminate?
not big enough for the Japanese audiophiles |
Well, Japanese audiophiles also stuff refrigerator size horn speakers into small apartments too so I guess I'm not surprised.
have you actually ever seen a furutech?? |
Yes. And the BAXLR's don't appear to be much larger than the Furutech.
i'm not privy to the costs, but there is more to it than silver pins.
for example, if you were to commission a jeweler of note to make 4 of these for you (which is in effect what you are doing, pretty much), you are commissioning an artisan to make functional art, I think it would cost you much more. |
Oh sure, if you go to the House of Faberge and say "Make me an XLR" they'd cost you plenty.
But that's just fantasy. If you want jewelry, just buy the Neutrik CrystalCONs with the Swarovski crystals in them.
What you're doing here is going to a machinist and commissioning them to program their machining center to spit out the parts you've drawn up for them.
se
