mcandmar
- Jul 5, 2013
I found when using a "balanced" output from a transformer output tube amp, i.e. the output transformer is center tapped and providing a + and - feed to each driver, the low end sounds better controlled, or more technically correct i should say it sounds better damped.
As for a true differential path from DAC's to amplifiers to the output stage, keep in mind you are doubling the amount of components in the signal path, hence the argument it can increase distortion is somewhat valid.
