After PROTECT i just power off and then power back on, using the power button.Hmm .. It’s hard to say what is causing it. Next week I have some days off work so I can try a few things from my side too.
One thing I’ve noticed that everyone having this problem is using a DAP as a source ? I have a few DAPs and will check this. I’ve always used PC as the source, which is why I bought this.
Question: After PROTECT appears what happens, do you have to reset the device or something ?
XDUoo XD05PRO
- Thread starter jockwong
With Shanling EC mini CD player, i used cd playback at 44.1KHz .I was just thinking. Playing with a DAP as a source, the bitrate changes for each song as these Chi-Fi DAPs do bit perfect audio output. Some DAPs even have a default very high Bitrate in between switching before identifying the correct bitrate.
Not sure if this is what is causing the PROTECT ? For me, with PC as source bitrate is constant as Windows doesn’t have bitperfect output. If my theory is correct the PROTECT would appear at the beginning of a song.
ToneDeafMonk
Previously known as TheDeafMonk
It is definitely a bit rate issue mine now goes into protection after I play the same playlist and when it hits that song that's it. Now I just have figure out what song and what bit rate it is.
Yes only happens when I use either DAP as a transport and not connected directly through balanced that's how I know it's not a op amp or DAC card install issue.
XDUOO needs to fix this and stop dening the problem exists!
After changing to ROHM DAC , no PROTECT mode so far and i am at song no. 15 from CD. 1 more song to go.It is definitely a bit rate issue mine now goes into protection after I play the same playlist and when it hits that song that's it. Now I just have figure out what song and what bit rate it is.
Ferdinando1968
I use it with playlists that contain PCM and DSD songs with often different frequencies and bit depths, and this has never happened to me so far, whether connected via USB or SPDIF.
However, my USB source is the smartphone (and not the DAP) while the SPDIF source is the WIIM.
stuck limo
Formerly with Light Harmonic/LH Labs
- Feb 6, 2016
Has anyone tried this with a Hifiman HE6se V2 ? Wondering how well it would drive that headphone.
Nice Sound with Trifecta Iems.. AKM Dac and V5i Opamps.. Hiss almost free,,
Best Regards
Sisco
Best Regards
Sisco
Replace Burson with any other op-amps and you will go from almost hiss-free to actually hiss-free. From all the op-amps I tried, the V5i-Ds have the most noise.Nice Sound with Trifecta Iems.. AKM Dac and V5i Opamps.. Hiss almost free,,
Best Regards
Sisco
Ben86
- Jun 24, 2015
Does that noise appear only when using XD05PRO with iems? I'm using V5i-D all the time in my XD05PRO with all my headphones and don"t hear any noise at all
I have many iems—RN6,Z1R,MMk3,Penon4,Advar,Xelento,FH7,Trifecta…..-only a very , very light hiss with Trifecta..and nothing with headphones.-Does that noise appear only when using XD05PRO with iems? I'm using V5i-D all the time in my XD05PRO with all my headphones and don"t hear any noise at all
best regards
Sisco
CharlyBrown
Similar for me. Only slight hiss with Multiverse Mentor, no hiss with the other IEMs and Headphones.I have many iems—RN6,Z1R,MMk3,Penon4,Advar,Xelento,FH7,Trifecta…..-only a very , very light hiss with Trifecta..and nothing with headphones.-
best regards
Sisco
When I tried with some of the IEMs, yes there was a lot of noise (I'm not picky btw, the hiss is loud enough to notice on sensitive IEMs) and I immediately ordered the Sparkos, installed them as soon as they arrived and haven't looked back.Does that noise appear only when using XD05PRO with iems? I'm using V5i-D all the time in my XD05PRO with all my headphones and don"t hear any noise at all
For me, the lowest noise are the stock OPA1612s, followed closely by the Sparkos. When it comes to sound, Sparkos all the way ! It does everything better than the Bursons in my comparison. Burson has a very slightly elevated bass. Sparkos has plenty of low-end too and I'm a bass lover.
hi, do you use ext mode?When I tried with some of the IEMs, yes there was a lot of noise (I'm not picky btw, the hiss is loud enough to notice on sensitive IEMs) and I immediately ordered the Sparkos, installed them as soon as they arrived and haven't looked back.
i tried 3 charger handphone for use ext mode (asus, xiaomi, huawei).. there is 1 charger give a lot of hiss when i use it.
i also use PD modul to force 12v..
but it didnt work at all, because when i switch mode (eco, normal, turbo), i always got UNLINK from my source (PC).. to fix it i must switch from ext to batt, then switch back to ext mode to make my xduoo LINK again to my PC.
then i order 12V3A DC adaptor to use as power supply in ext mode.. no hiss at all, now i can switch mode eco,normal,turbo without encounter UNLINK problem again.
Incredible synergy with fostex th900 mk2 purple..Source Shanling CD EC3, connected by coaxial to the XD05 Pro
The XDuoo is a really competent gear
Best Regards
Sisco
Best Regards
Sisco
Total: 6 (members: 1, guests: 5)
