hongky
- Mar 13, 2013
Is there any space to put something bigger like Sparkos SS3602 ?My burson just arrived today and I’m happy to say that they does fit in nicely.
is it safe to say that the v6 won't fit?My burson just arrived today and I’m happy to say that they does fit in nicely.
i don't think they fit as there are 4 capacitors around the opamp and they are right next to the burson without much space left.Is there any space to put something bigger like Sparkos SS3602 ?
no way, v6 is way too tall and the space needed is not deep enough as the way the opamp sits, it is going up against the top oled screen.is it safe to say that the v6 won't fit?
Please let me know the comparison of the bal2 vs the Pros if you can, thank youXD05 Pro just arrived, I do think it walks a tight line between portable and desktop class DAC/amp. Here are some comparisons to the FiiO Q7 (massive already), the recently released xDuoo XD05 BAL 2, and the Questyle M15 to represent a more typical portable DAC/amp:
They look like oled screens, in my experience those burn-in, they look nice bit after hours of showing the same thing the few pixels that are on start to lose brightness.Why do you get the feeling that displays can burn out with continuous use, if I may ask?
I read in the specifications that the output amplifier stage is class A, in your opinion does it sound like class A?
Thank you.
I think the amp section sounds good, it’s not overly warm if that is what you are after. It’s good at driving headphones though.
i owned Questyle M15 . is it big gap in terms of sound quality such as resolution, sound stage and imaging ? is it worth to upgrade ?XD05 Pro just arrived, I do think it walks a tight line between portable and desktop class DAC/amp. Here are some comparisons to the FiiO Q7 (massive already), the recently released xDuoo XD05 BAL 2, and the Questyle M15 to represent a more typical portable DAC/amp:
One would dare to locate and cut square openings into the plating just so it can fit the v6?i don't think they fit as there are 4 capacitors around the opamp and they are right next to the burson without much space left.
This one is more like transportable, maybe someone can design a sling to carry it around. Definitely smaller than the new Lotoo Mjolnir, and that one has a carrying case.Honestly...kinda bummed at how absolutely gigantic this thing is. I was hoping for something about the same size as the Q7. What appeals to me about this is the interchangeable DAC cards, and not being forced to use ESS like you are with the Q7. But Fiio is also coming out with the Q15 soon and I wonder how that will compare and what DAC it will have.
In either case, I'm still strongly considering this one. Just have to consider how valuable portability is to me.
Although I do like this unit, I hoped for more customizations options: color of unit, color of volume control nob, color of the oled screenHonestly...kinda bummed at how absolutely gigantic this thing is. I was hoping for something about the same size as the Q7. What appeals to me about this is the interchangeable DAC cards, and not being forced to use ESS like you are with the Q7. But Fiio is also coming out with the Q15 soon and I wonder how that will compare and what DAC it will have.
Just looked up the Lotoo Mjolnir, that is quite clever, I like the idea with the carrying case haha.This one is more like transportable, maybe someone can design a sling to carry it around. Definitely smaller than the new Lotoo Mjolnir, and that one has a carrying case.
Tell me please how much sound change when using "Burson v5i-D" compared to stock op-amp???My burson just arrived today and I’m happy to say that they does fit in nicely.
