Max61MI
Also on page 141 user gmalik writes about modifying the opamp board:
https://www.head-fi.org/threads/xduoo-xd05pro.964620/page-141
If you are planning to upgrade to the Sparkos SS3602, know that I discovered that on Aliexpress they also sell a clone, called OP8802 and which costs half the price:I finally bought an XD05Pro for myself after 6 months of searching.
Before that there were several sets on listening at home, better and worse. Curiosity and the possibility of changing the sound of the XD05 decided to buy it.
In my opinion, it is technically superior to the K11, K7, K9Pro ESS, Topping XD5, SMSL M500 Mk3.
I still listened to the R9, but it was out of the house, it didn't impress me, so I don't regret even taking it home.
XD05Pro, has been playing for about 25 hours, even managed to warm up to 33 degrees in turbo mode, I took a 30 minute break and turned it on again.
It is working at my place in stationary mode at the Pc, powered by Tomanek ULPS Mini, on KZ AS16 headphones.
On the shelf waiting AKM, in the plan Sparkos dual discrete operational amplifier SS3602
My brain is probably burning out because my leg is starting to go at some points.
I wonder how much I'll like it when it loses 100 hours, though I don't know if that's required and what will change when I change to AKM and Sparkos.
It's nice to be able to modify it.
Another thing is I keep thinking about better IEMs, I would like to spend as little cash as possible.
What in your opinion is worth buying from IEM?
Greetings .
I have no idea for this. Apparently a modified opamp module solves the problem. Someone wrote about it a little higher. For me it looks like this:@quaddac
I read that you also heard white noise with all iems. Could you share with me your experiences on how you were able to reduce the noise to a minimum? In which mode is the deadliest white noise lower in the case of iem? batt or ext? What power supply did you use? does opamp replacement play a role in this? @quaddac
https://it.aliexpress.com/item/1005006684321509.html
I think sooner or later I'll decide to take it; the only review talks about it in enthusiastic terms, and comparing the photos it actually seems to be identical, both in terms of construction and components used.
Shop with 75% and 60 followers.If you are planning to upgrade to the Sparkos SS3602, know that I discovered that on Aliexpress they also sell a clone, called OP8802 and which costs half the price:
Is this the exact one?Hi,
I received burson audio v5i dual 2pcs for free by Burson Audio. Thank you!
The stock opa1612 sounds flatter and less dynamic compared to the v5i. The high, low frequency is a clearer and more real sound.The bass hits deep and stronger. The midrange is less warm, more on the neutral side, but with more detail and air and more 3d effects!
Important, it sounds deeper with the burson v5i kit.
I don't change op amps anymore.
Exactly!Is this the exact one?
Burson Audio Supreme Sound V5i Dual
If you search for OP8802 on Aliexpress you will find at least 30 different stores that sell it; I linked that one as an example because it had a review that seemed interesting, but as another example this other store (which has already sold 6 of those) instead has 96.3% and 6800 followers.Shop with 75% and 60 followers.
Good luck!
As for the Burson Audio Supreme Sound V5i Dual Opamp, do you need to modify something there to trim, compared to the original OP, complicated to insert?Exactly!
You don't need to trim Burson V5iD at all, just make sure correct orientation and insert.As for the Burson Audio Supreme Sound V5i Dual Opamp, do you need to modify something there to trim, compared to the original OP, complicated to insert?
Curious about the differences from the Sparkos SS3602, anyone compared them?
