skajohyros
It should work if you're careful. Good luck!
Update.
Thought I 'd try a torx 6 in the stripped hole. badaboom. Worked! Now, where the hell am I going to find another screw?
Update.
What kind of shop is Lowes? In Australia it's a clothing store. Now I'm living in Greece and there are no Lowes here. Will try an auto shop.
Update.
I just received an X3 today.
Before I search the entire thread or risk that my cards are accidentally formatted, I'd like to ask whether the (stock, not rockboxed) player takes exFAT cards for both slots or requires them to be formatted in FAT32.
Stock read exFAT but RB will require FAT32 so why not format it in FAT32 for later?
as long as the stock firmware doesn't lack anything that is a must-have for me that only RockBox could solve.
Well Rockbox does play files back at the correct pitch.![]()
Second card slot not reading sd card - The second card must be formatted to FAT32 and have the .rockbox folder in the root directory.
