Rixsta
- Sep 9, 2010
Anyone know if this player will be able to handle higher than 128gb ? Thanks
Does this have genre and artist play options?
Hi!
I charged my new rockboxed X3 5 hours with notebook USB, but the battery is still at about 50%.
What's the problem, hardware or rockbox?
Thanks.
Hi!
Thanks.
It's probably my first post here although I've been on here since 2012!
But is anybody else other than me finding this little player a bit difficult to love? Not because of the sound quality but because of the other things about it.
It takes me almost twice the time to charge the battery (6-8 hours) than to run down the charge (4-5 hours).
Depending on how the charging is done (USB to computer, 1 Amp charger, 2 Amp charger) - the device either gets worryingly warm; or hotter than the sun.
Depending on what files are being played, same thing. Not as hot as when charging, but not-a-nice-feeling-in-your-pants-pocket kind of warmth.
I found that Rockboxing it exacerbates the heat/battery drain problem, but the stock OS/User Interface is still really warm, and the battery drains quicker than I like and charges slower than I like.
Just me? Should I bite the bullet, put it down as a learning experience and get a Cayin N5 instead?
I agree with you completely.Hi guys,
I have my own xDuoo X3 and I find one major problem with this product - the screen. Its completely illegible while staying in sunlight (not even at noon!). .This is why I wonder... is there any screen replacement for this? Any ideas how to fix this problem?
Many thanks!
K
I've seen a mod where someone took off the 'transparent' plastic part that sits on top of the OLED screen. That plastic part is Grey-black transparent which filters some 40% of OLED brightness. We all would be helped when xduoo shipped us a completely transparent replacement part (with no color) that we can swap with the factory installed part.
But hey, this is xduoo, will never happen! :-/
