Astrogoth
- Dec 15, 2011
My X2 runs 6.0; is there any noticeable difference between 6.1 and 6.0 that you know of?
Not that I know of.
Okay so it looks as though Xduoo X2 has problems with the duplicate invisible files left behind after file transfers using OS X. I deleted the duplicate files using BlueHarvest (http://www.zeroonetwenty.com/blueharvest) which solved the 'Format Error' messages, but now the files are listed out of order on the device.
Any ideas?
Thanks again
Okay another thing: does anyone else's X2 occasionally exhibit an audible elextrical drone when the unit is turned on? The noise changes (it kinda modulates) depending on how the unit is held and seems to go away when the unit is reset?
An update: I can reliably reproduce this noise if I place the X2 next to a mobile phone and rub the two devices together. The noise varies from phone to phone but it sounds similar to the sound I remember hearing over a car's radio when a mobile phone receives an SMS when near the receiver.
I feel like this might be an issue with many other X2 units and not just mine?
Thanks for all help,
Max
is this a rebrand of X2? Jaben's Hippo Mu looks identical to X2, anyone have tried it?
Seems interesting. Is there any link about it?
