emilsoft
- Dec 5, 2014
That was my concern, it will sound close to the original xdsd - it if were close to 300 pounds or so I might think about it but the pricing seems out of proportion. I can get rme adi 2 for almost the same money, or fantastic multibit Schiit stack with class a amplifier - I know it's not portable but looking at the components cost and other things I can't see where the value for money is in this if the sound quality is close to original xdsd (as it should be as the DAC chip and setup looks to be very similar )Similar implementation, but as I mentioned before it functions slightly differently as the volume level can be controlled from the source device, I don't remember my xDSD being like that.
I like the sound, no hiss, no "glare" that I can hear. I'm not going to try and compare it seriously to other DAC/AMP's I own because most of them output a frequency response that is essentially flat from 20Hz to 20Khz so as long as the amp has the power to drive the load and the impedances are properly matched, they all sound the same to me, not saying some people can tell a difference, just that I usually can't.
I can't really hear much difference between the xDSD and the xDSD Gryphon to be honest, as I mentioned before I would have been happy to stick with the original xDSD but this one has xCAN built in and better BT Codecs so I decided to "upgrade".
