Hinomotocho
I originally checked on PC which displayed the same firmware number, then confirmed on the device.Err .... I guess so, I have never seen that on my Gryphon, perhaps it is very early firmware which displays its own code ??
You can confirm the firmware by downloading the various stuff from ifi, pugging the Gryphon into a PC and opening the tool that allows you to view the firmware details.
That tool is the cpl file, control panel I guess, the firmware updates are done through the dfu file, device firmware update I assume, after downloading those and the appropriate firmware.
The bluetooth firmware updates reads like it is very complicated on the poorly written ifi instructions , it isn't. Download the Gaia app to your phone or tablet, download the bluetooth firmware to the same device, turn bluetooth on the device and the Gryphon, THEN DISCONNECT THEM, open the Gaia app, find the Gryphon, it will be called Hi Res LE or some such, select it, select the update option and point the Gryphon to the downloaded firmware, the update takes a few minutes so be patient.
I just upgraded the firmware, I'll now do the bluetooth one.
I appreciate your guidance.
