rlw6534
I now realise something. The 2 cells may be wired in parallel, not in series.
The stated battery capacity on the box is 3600mAh (which is exactly 2350mAh + 1350mAh shown in your pictures).
If the 2 batteries were to be wired in series however, you will only use 1250mAh from the large one, not the full 2350mAh (so the total capacity would be 1250mAh).
So what they're doing here is most likely the following:
1. They both discharge until the small one is fully depleted and will not supply current anymore (stopped by its own protection circuit);
2. When just the big one remains, that is when the charge will drop faster, since it's only one that supplies current;
In this case, relying on the cells' own protection cicuits is the only way (I can think of) to use them in parallel and not fully discharge the small one.
However, I think the firmware should be adapted so it displays the charge a bit more accurately (especially after the small one is discharged).
Mine does last 4-5 hours (rough estimation, may be a bit more actually) at pretty loud volumes, so I think the cells are just fine.
Batteries wired in parallel will stay naturally balanced because they have to operate at the same voltage (cathode connected to cathode and anode connected to anode). Essentially they will provide current proportional to their capacity. In this example for a 0.1 amp draw the small battery will provide (1250/3600) or 0.0347 amps and the larger 0.0653 amps. That can't discharge separately without complex circuitry to vary the voltage on each cell.
