xDSD Gryphon: birth of a ‘head-fi’ legend
- Thread starter iFi audio
HiFiLoSigh
Right - how about comparisons with the Mojo?
Hello i am new to this and thinking about this or the Mojo 2. What do you think? I have a pair of Focal Stellia's (4.4mm), beyerdynamic T5 (3rd Gen) 4.4, Hifiman he400se 3.5 (but will get 4.4), also a pair of UE IEM's. I would be using a laptop or phone to drive the music primarily.
HiFiLoSigh
you can update the firmware through the app?Anyone have issues with the GAIA firmware step? The app itself just is stuck on scanned and shows a spinning circle. Oneplus 7T
GridIroN
There's a set of little programs ifi has that do it on their support page.
HiFiLoSigh
Okay, because right now I just have Chromebooks. So if it needs a PC or Apple it is a deal-breaker for me.There's a set of little programs ifi has that do it on their support page.
HiFiLoSigh
Hello, I am a NOOB and I am thinking about this or the Mojo 2. I have a pair of Focal Stellia's (4.4mm), Beyerdynamic T5 (3rd Gen) 4.4, Hifiman he400se 3.5 (but will get 4.4), also a pair of UE IEM's. I would be using a laptop or phone to drive the music primarily, and I prefer over-the-ear headphones.
Any thoughts? Thanks!
KaiFi
If you care about balanced (and it sounds like you do), then I think this is the clear choice. It's more functional, it's balanced, and it's more affordable. I haven't heard them both, but I did own the original Mojo and while it's hard to compare (especially since it was years ago that I heard it), the Gryphon and Mojo are probably similar in terms of sound quality. The Gryphon just offers you more.
@iFi audio is there any disadvantage to connecting headphones to the line input/output slots? I have been connecting my headphones to this side for ergonomics for the past couple of days. Just don’t wanna give myself a disservice if there’s a disadvantage to doing that.
AlexxxAA85
I would like to know if anyone has noticed anything different as well?@iFi audio is there any disadvantage to connecting headphones to the line input/output slots? I have been connecting my headphones to this side for ergonomics for the past couple of days. Just don’t wanna give myself a disservice if there’s a disadvantage to doing that.
I feel like connecting to the back on either 3.5 or 4.4 seems to have less power than in the front next to the knob. Unfortunately I'm out of town without the Gryphon so i can't keep testing it, but that's the impression I got from using the rear jacks from what I remember.
This is a dedicated line out.I would like to know if anyone has noticed anything different as well?
No current gain, just simple voltage driven line output.
chaotic_angel
Hi Cool set up for DCA aeon - do you find it is driven properly (not only sound LOUD) ?
HiFiLoSigh
It matters to me because normally balanced is better but isn't a selling point to the mojo 2 that there is no need for balanced?If you care about balanced (and it sounds like you do), then I think this is the clear choice. It's more functional, it's balanced, and it's more affordable. I haven't heard them both, but I did own the original Mojo and while it's hard to compare (especially since it was years ago that I heard it), the Gryphon and Mojo are probably similar in terms of sound quality. The Gryphon just offers you more.
Actually Chord designed all of their DACs optimized for SE (from Mojo all the way to Dave) hence they say that balanced does not improve on the Chord sound. But for most other balanced DACs/Amps, usually the balanced connection is better.It matters to me because normally balanced is better but isn't a selling point to the mojo 2 that there is no need for balanced?
Yepp, definitely.Hi Cool set up for DCA aeon - do you find it is driven properly (not only sound LOUD) ?
chaotic_angel
that's good to hear, I have MrSpeakers AEON closed back (blue color) and always having trouble driving it with portable device.Yepp, definitely.
Total: 13 (members: 0, guests: 13)
