True, but if they 1) add a BT codec enable/disable option, 2) add a volume limit option, and 3) add a desktop mode, Gryphon's stock will shoot through the roof. I also think all three would be fairly easy additions to make, and won't affect the current functionality of the product one bit.
Our software team will be back after CNYa after the 9th and I'll hear back from them when on the possibilities of these requests are!
Agree, adding these three features would be great. For my part, I would like to suggest adding the LDAC locking option in 990kbps 44.1kHz 16-bit mode, so that you can listen to audio CD tracks losslessly. An even better option would be if Gryphon remembered the last bluetooth setup and connects to Android with the same parameters. At the moment I have to enter the development options after every Gryphon connection with Android and manually set 990kbps 44.1kHz 16-bit.
