Battou62
- Mar 6, 2011
It would probably be better just to get some high quality, low rpm fans instead.
Wow, I've never heard any one say that upgrading their psu made video's loom better and increased their access times.
Clearly this is impossible so I think we have a bit of the placebo effect going on here.
Also I can't tell if the op is using a soundcard or onboard sound but if he is then the psu should definitely make some difference,
but if using an external dac there is almost no physical way that you would hear any differences unless your pc was massively underpowered to the point where it was causing massive voltage swings in bot the cpu and ram.
