sennsay
Did you buy your cable from Sennheiser, or is it a replacement from elsewhere? No looseness in the pin sockets? I may have to buy a set next year and I'd like to try a set of pads more like the Focus pads on my HifiMAN HE400S - pleather sides and a velour face with a little more depth. The new pads, which I think are the same as yours, are not quite as comfy as the stock pads and I'd simply just like the best of both worlds!This pair of 540's came with third party (worn out) pads. It was a pain to remove the rings, once I got them out it was a simple job to slip off the old pads and fit the new pads and foam covers.
They certainly do add some body, I've yet to hear a reduction in soundstage, bass has firmed up without any intrusion into the mid-range.
The 650 cable fits perfectly and add's a little extra warmth and bass, only a tiny amount that does no harm to the signature of the 540's.
