Alizz
- Sep 21, 2015
Thanks, any idea how to dissamble it?
Thanks, I will try.
I just resurrected my Sennheiser HD 540 Reference ii headset, I'm ordering replacement earpads for it. I owned the original 540 and and Pair of HD 600s, I prefer this model to those for different reasons...chI fly the balance of transparency vs. soundstaging...very hard to beat. I need a good portable headphone amp for them, perhaps the Oppo I've seen going for $299.00.
I ordered from an eBay seller, hoping fit and finish are decent. I have the original pads but the foam baffle is toast.Where did you order your headphone ear pad replacements from?
Thank you for the recommendation, I'll check that out, I hadn't considered a tube setup but I'm open to suggestions.Hi Alistair
I also have and use these as well as the 530's, 560's and the 250.
I can't reccomend enough the Littledot1+ Hybrid solid state / tube amp - I cant speak for the other Little Dots but from personal experience it is extraordinarily great
There are many tubes you can buy for a reasonable price on ebay so you can tailor the sound how you like. Actually you also upgrade the internal Opamp
Considering it only around $100 you really cant go wrong!
