The difference is huge. A completely linear sound from the very bottom to the top end, it will tell you exactly what is happening with your amp and DAC side of things, as well as the quality of your source. Basically, the Mogami cable is an open book, just as a top class microphone cable should be that's used in studios worldwide. If you hear something dodgy it won't be the cable! It's not a tone control. While the stock HD6XX/HD650 cable is pretty good, the Mogami bests it easily in extention and an extraordinary ability to leave the signal alone, letting it speak for itself and allow voices to sound exquisitely human and fleshed out. Again, source and amp/DAC dependant, the Schiit stack is brilliant at that.
The stock cable that came with my now 29 year old Ref1s, adds an upper midband edge, overall grain and less density in the bass. Still good if you have nothing else, but the HD6xx cable is quite superior and fits right in there too. It has slightly less of an effortless presentation and seems to push the mids a little forward of neutral, a touch brighter, though clean with it and is a good option with the Senn HD540s.
The Mogami passes music with a sonic ease that is hard to beat. Effortless dynamics too.
Again and again, I make changes to the Ref1s and always come back to the sheer ....... here's that word again ... effortless musicality of the pleather pads and Mogami 2893. Did it again last night and I really don't know why I bother
Popped the new German 'orhpolster' pads in and they lasted maybe 10 minutes. They thicken up the mid bass and make it a little thumpy, sharpen up the mid focus and there is a noticeable lessening of the sheer 'out-of-the-head-and-cans' disappearing act that just happens like magic with the shallower pleather pads and their oval ear openings, AND is de rigeur for the HD540s even as stock. Those German pads did exactly the same with the HD250s as well, so it seems I haven't found the best home for those pads yet. They appear to compress and colour the bass, whereas my favourite pleather pads allow the bass to flow unhindered in a completely linear fashion. Although there is great depth and weight, an organic aliveness that seems to evade everything else I put in the Ref1s, it never colours the lower midrange. For example, Daft Punk's R.A.M., specifically Giorgio Moroder, where Giorgio's resonant voice is never coloured by the thumping bass beat underneath it, something easily noticeable with the HD250s no matter what I did.
I'm considering my options with the HD250s, the guy who sold them to me said that he would happily buy them back if I decided that I didn't want them. I may do yet. I'm thinking that the money shagging around with them might be better spent on a set of HD540 Ref Golds.
The only thing I want to try now is to use an even thinner inner foam in the Ref1s, just to see if I can add just a smidgeon of greater illumination in the very top end. They are pristinely clear and focused as they are, I would just like to hear the house lights turned up a little biddy bit
If I can't do that without denigrating anything else, they will be complete as they are, their JOY Level is already outrageously satisfying. Nothing can 'out-rhythm' them! Some come close but miss out in other areas. Refs Rule!
