a Chinese manufacture trying to maximise their profits by selling low quality products? no way.
I don’t doubt there’re cable snake oil salesmen out there (I can name a few) -- but to think that a high end audio manufacture (i.e. Audio Research, to name the first that come to mind), instead of investing their resources into research and improving their components, would deliberately hobble their products to make them sound different, it's ridiculous.
I don't know whether the likes of Meridian and McIntosh are considered as high end manufacturers any more, but you better believe it, and there is nothing ridiculous about it, it's basic business nous.
One has to differentiate oneself, create a 'sound', an 'image', a 'brand' to get a head in the market. Adding some pleasant harmonics, rolling off the high end etc. is just one way to do this.
yeah, fairy tales, like most of the comments in this forum.
the fact remains that you (like most of the others...) have never own, or even tried better quality cables. Isn’t that worth noticing that most (like 99%) cable skeptics have never own better cables?
also, you've never owned a DAC, ever. but you seem to be totally 100% sure that jitter is inaudible. you haven’t a clue what a system where jitter has been in part corrected or removed, sounds like.
it's a shame
I've never owned a high end cable (unless a Qables silvercab LOD count?), but early on in my endeavour I had the opportunity to borrow a few highly thought of Van den Huul cables so I could figure out what all this fuss was about. I had three cables: one basic one from a local high street store, one low end VdH and one moderately high end VdH. Sitting on the floor plugging in, plugging out, and generally mucking about, I could clearly hear some differences. One was harsh, the next was mellow, while the last one was sweet. No guessing which was which.
All seemed fine and dandy, and I figured the ~$100 for the low end VdH seemed reasonable, until one day I came home from school and sat down to listen to some tunes. It was blissful! Everything seemed right; sweet, clear, punchy, everything! I figured "woah, this high end VdH sure delivers some quality, maybe I really should splurge?" Imagine the surprise then when I looked behind the the CD-player to remove the cables so I could return them, only to discover that the cables that was in use was the cheap generic ones! Next thing I did was to try out the other cables to see if they could possibly sound even better than this. They didn't, if anything they sounded worse.
And thus the scales fell from my eyes, I had discovered that the mighty wizard was little more than a sad little man acting all high and mighty. Never again have I tried do do any sort of critical evaluations sighted.
