bigshot
It seems there is some difference between cables.
Are you referring to the color of the insulation around the wires?
dynamic single driver headphones are much simpler loads than multiway loudspeakers - headphone impedance curves are generally smoother - the bass bump, voice coil impedance rise are at frequencies we are relatively insensitive to
Obviously I am not referring to the insulation color. Are you actually part of a discussion or just 'pointing fingers' at people who do not blindly accept everything you say regarding audio technology?
Makes sense.
Vs = Va * [ (Rs^2 + Xs^2) / ( (Rw + Rs)^2 + (Xw +/- Xs)^2 )]^(1/2)
I think he's pointing out that the biggest measurable difference between cables is aesthetics.
If you can define a case-study system for a discussion about the possible affect the cables could have, then we can move forward with defining the upper bounds on the audibility of cables in such a system.
Cheers
Yes, I know what he was saying.....I just don't know what it has to do with the discussion. The same goes for the pricing of cables. I honestly don't have an opinion on the subject of cables...that's why I'm here. I wish the mocking statements would stop. I'm pretty sure that won't happen though.
I did post an article earlier that one person (jcx) posted a response to. I thought what he said made sense...and said so.
I realize my ears do not qualify as a case-study, however, I swear that the instrument separation and details between two cables I own are different. I don't have a way of doing a proper blind test or abx text, but I'm pretty sure I could identify the cables in such a test. Like I said earlier I have two cans I can use these cables with. The Mr. Speakers Maddogs and Vmoda M80's. I don't hear much of a difference between cables when using the Maddogs, but with the M80's I do.
For the record I'm comparing a stock Vmoda cable (included with the Maddogs and M80's) and the Moon Audio Blue Dragon cable. I assume the gauge of the wires in the Moon Audio cable are larger than the Vmoda, but I have no way of knowing.
So is this an accurate model of a speaker system?
The whole reason to do controlled testing is because you CAN'T be "pretty sure" about anything that subtle without doing one.
That said, there is more likelihood that an expensive audiophile cable would sound different than an inexpensive one. Sometimes audiophile equipment is deliberately hobbled so it sounds different. But "different" in these situations doesn't mean "better".
A simple switch box is the best investment you can ever make. It will save you hundreds and hundreds of dollars in unnecessary expenses on equipment that makes absolutely no difference. It's ironic that you perceive someone who is trying to help you as someone who is mocking you. I'm not mocking you. I am pointing you in a direction where you can know "for sure", not just "pretty sure".
High end cables are a total ripoff. You are a fine person. My scorn is reserved for the scam artists that propogate misunderstandings like this. They are mocking audiophiles all the way to the bank.
Some interesting reading from one of the top engineers at MacIntosh...
http://www.roger-russell.com/wire/wire.htm
I think you just missed my previous post
You can always ask Moon Audio what gauge wire is in your cable, same as Vmoda. You can try some typical numbers in the equations given in that paper you linked, and you'll find all the results suggest fractions of a dB only at the the extreme limits of audible frequencies ... I speculate that would be very very difficult to identify in a blind ABX test (impossible?) unless you have a very special set of ears.
It is trivial to plug some numbers into the formulas in the paper you linked. Give us some background info of your setup, and I can (and I'm sure the other folks here as well) can easily help you quantify the impact of the cable choice.
Cheers
Thanks for the thoughtful response. I've been careful to try not to use the term "better" when describing what I hear....just "different". If I did use "better" at some point I didn't mean to. I'll check out the article you linked.
I did see it. I can look up the impedances of headphones, but I don't have a way of accurately measuring reactance of anything...or the impedance of cables. Any advice for doing this? I have the formula plugged into a spreadsheet so I can play with some different numbers. Would be happy to provide a list of the equipment I use. For all I know this information is already available.
