World's first portable Hybrid Valve Headphone Amplifier (with a footprint smaller than most cellphones).
May 2, 2015 at 12:58 PM Thread Starter Post #1 of 181
PurpleAngel
California
https://www.kickstarter.com/projects/970055861/hybrid-valve-headphone-amplifier
Not sure if anyone else has posted about this.
May 2, 2015 at 7:31 PM Post #2 of 181
It's so cheap, so cheap that I don't want to buy it because I'm afraid it will sound bad just based on the price.. Haha.
Please go ahead and prove me wrong though. I've been eyeballing the new AK100II and AK-JR but getting away with spending 120€ would be just fine with me. :D
May 3, 2015 at 12:52 AM Post #3 of 181
I'm just so proud of this coming out of New Zealand. I might actually for once be able to try before I buy. It is insanely cheap but those who have heard the prototypes seem to like it. I asked whether there was a possibility of bypassing the output DAC in future models, just waiting on a reply. Also maybe the thread starter wants to change the thread title to just "First portable valve headphone amp". See if we can generate some interest.
May 3, 2015 at 1:13 AM Post #4 of 181
I shorted the thread title a little.
May 3, 2015 at 1:28 AM Post #5 of 181
I should have a review sample by Tuesday or Wednesday (hopefully) - so review coming.
May 3, 2015 at 4:39 AM Post #6 of 181
Awesome! Just got a reply on Kickstarter to my above question: "Hi Andrew. Thanks for your input. Yes -if we have enough interest in adding a DAC, we will add this as a stretch funding goal and set this as a separate model."
May 3, 2015 at 8:02 PM Post #7 of 181
How is this the "world's first"??
http://www.fostexinternational.com/docs/products/HP-V1.shtml
http://www.elekit.co.jp/material/english_product_html/TU-HP01.php
http://www.head-fi.org/products/alo-audio-the-continental-mobile-vacuum-tube-amplifier
http://govibeamp.com/index.php
May 3, 2015 at 8:37 PM Post #8 of 181
Read the second part of the heading ....  "with-a-footprint-smaller-than-most-cellphones"
I'm guessing that was what OP was meaning.
I should have comparative photos later in the week.
May 3, 2015 at 10:04 PM Post #9 of 181
Miu Audio used to have one of those....
...seems to have gone out of production, though.
May 3, 2015 at 10:13 PM Post #10 of 181
No volume control?
May 3, 2015 at 10:52 PM Post #11 of 181
I'll let you know in a couple of days if you're patient
May 4, 2015 at 4:06 AM Post #12 of 181
The "with a footprint smaller then most cellphones" was just something I copied from the review, as I could not think of anything better to put in the thread title.
May 4, 2015 at 5:21 AM Post #13 of 181
Thanks - I'm assuming that's why they've made their claim (size) - because there are definitely other portable tube amps out there (I've owned one previously - the PortaTube).  I guess that's why I'm so interested in this.  The PortaTube sounded sublime.
May 4, 2015 at 5:30 AM Post #14 of 181
A bit more information from Martin.
There is no volume pot - that's controlled from the phone/DAP/source.  Initially he was going to release two models - a high gain and low gain, but he's just had a new prototype completed (he's waiting on PCBs to arrive shortly) - and this will give buyers 3 options (high / off / low).
I'm going to quote some of his message to me - as I really like how open he's being with information.
I'm sending you two Amplifiers. Your question #1 is relevant to this. You're right there is no potentiometer. In designing the Amp we decided the best way to control the volume was at the source eg MP3 player. We wanted to achieve uncompromised sound and found that all the small carbon tracked potentiometers small enough for portable gear added noise to the signal. We had gone to a lot of bother using metal film resistors throughout so we wanted to stay true to the design.
However we noticed that with some very sensitive headphones (particularly IEMs) there was some background 'hiss' present. The hiss was not present at all on some other headphones. So with the new design which is coming out for Kickstarter soon we've added a 3 way ON/OFF switch where the centre position is OFF and then depending on LEFT or RIGHT you can select high gain or low gain depending upon what type of headphones, their impedance etc. This completely removes the unwanted hiss is you have very sensitive headphones or in ear type.
I haven't got the new PCB's back for this design yet they're still a week away so I've sent you two amps, one set at high gain and one low so you can try them both.
Second question- output impedance. The OPA2134 can handle anything down to 4 ohms. The data sheet in fact states it is protected against a direct short at the output so there's no output impedance restrictions. I tried today some Sennheiser HD700 which are 150 Ohms and there was plenty of drive from the Valve Amp and plenty of volume.
Third question- I'll set up some tests for the 16-300 ohm loads. I'll run the Amp's output into these loads and measure the voltage across the load on the oscilloscope and give you these figures in a couple of days.
I've explained that I'm looking for actual output impedance on the headphone out - so we can check damping factors. And by next week we should also have power output figures.
I should have both high and low gain amps hopefully by Weds - so I'll post pics and give impressions of sound as soon as I can.
May 4, 2015 at 5:42 AM Post #15 of 181
He's also considering adding a volume pot if enough people request it.  I've advised that it might be worth looking into - especially if people would prefer using it from a DAP with a line-out.
More info later.
