Nadim
- Sep 21, 2002
A while ago I posted asking for suggestions for a work system. I did a fair amount of reading and research, and then it was all placed on the back-back-burner as I moved cross-country, bought a house and car, and generally let a lot of other things slide.
Anyway, I'm back, I'm still hungering for something better than my current setup, and my wallet is in the process of recovering enough that I might actually be able to do something (small) about it.
This is one of those "whole system" questions, but I'm not sure if any other forum is more appropriate than this one... Anyway, first, my requirements: I'm looking for a small system for work. Unlike some, security restrictions at my work environment doesn't permit me to use my computer for audio, much less to actually crack the case and replace the crap built-in audio with a decent sound card. However, it's a pretty safe place so I don't mind leaving gear there. Desk space is a premium, so I can't use full-size components...only the boutique-y small stuff. Also, I'm looking for a bang-for-the-buck type starter system, not a no-holds-barred system. That said, here's what I'm thinking...any and all comments are more than appreciated (otherwise why would I post this?
First things first, headphones: I'm thinking Beyer 770's.
Why? I want closed cans, but my Ety's are too much of a pain to take in and out, plus eating a bag of chips with lunch sounds like the building is collapsing...
I need something comfortable for hours at a time, and a slightly darker sound would probably be less fatiguing to my ears for all-day listening as well. The bass isn't bad either.
Second, what to drive them with.
I was thinking a cheap transport with an inexpensive outboard DAC and headphone amp can all be had together for the same price or less than the price of most of the smaller systems that would begin to be acceptable (like the Denon D-F101 I had my eye on earlier).
Transport: Sony CMT-EX5
Why? Cheap, small, good controls and CD-text display. After all, that's what I want from a transport anyway. Nicer than PCDP (tuner-wise and display-wise), and doesn't have a tape deck with record (no recording devices allowed...). Sound out-of-the-box is pretty crappy, but who cares, it's got a TOSlink out. I'll leave the speakers that come with it in the closet, or donate them.
DAC: ART DI/O or Channel Islands VDA-1
I can't quite decide on this one... The ART is cheaper and has gotten some good reviews, but it seems like a bit of a pain to interface with...since I'd have to get a TOSlink to coax converter box and RCA to coax connector, plus the hot output may cause additional problems. The Channel Islands DAC looks more suited to my application, but is a bit more, and I haven't found as many positive endorsements...
Amp: Corda HA-1
Why? Has gotten good praise, has crossfeed to play with, 120 ohm output (supposedly Beyer's like that?), is inexpensive.
I figure I should be able to get the Sony/ART/Corda for $700, or the Sony/VDA-1/Corda for $850... A little more than a Denon / Yamaha microsystem with a decent DAC and jack built in, but probably a little better too (and full of audiophilesque separate-component goodness).
I know the typical advice is, of course, "listen and decide for yourself", but none of these components (with the exception of the Sony, which is nicely designed, but has distinctly dissatisfying audio, when listened to with my Ety 4p's in the store) are available for me to listen to without buying and returning at my own shipping expense. So any nuggets of wisdom about better choices, things I've overlooked, or praise at my thoughts (sure....) would be greatly appreciated. Thanks!
-Nadim
Amp: Corda HA-1
-Nadim
