bpiotrow13
Can you please explain a little more what you mean here “(only plug instead of out).” Or if you don’t mind can you take a picture of it.
Sure, thanks, below
It says nothing, i guess it is 1st gen than. Does not make a difference for me, just wanted to know.If it's 2nd gen, it will say 2nd gen on the back of the unit.
Looks to me to be a Ver.1Sure, thanks, below
Seems so. Does not make any difference for me. Just wanted to know. Thanks.Looks to me to be a Ver.1
New Kid on the block.
Looks like the WA 5-LEDoes not look like Wa22
Could you describe sound differences?
How does this do compared to the WA22/WA33 ? I am looking an amp for my HD800 and HE1000 v2, does it pair well with the amp?New Kid on the block.
It’s hard for me to say I only have a few hours on it, but what you notice right off the top is it’s more textured for sure and Way more dynamic.Does not look like Wa22
I don’t have the 33 so I can’t speak on that one but I will say I liked it better than the wa22, you can tell that right away that it is different more dynamic and instruments and vocals have more texture. I do have the HEKse and this is a match made in heaven for them.Looks like the WA 5-LE
thanks
Thankyou for the reply. Will run by the local dealer to get a try on those !I don’t have the 33 so I can’t speak on that one but I will say I liked it better than the wa22, you can tell that right away that it is different more dynamic and instruments and vocals have more texture. I do have the HEKse and this is a match made in heaven for them.
Thanks, these are mostly 6as7g substitutes. I think i have GEC 6as7 g, need to look for it. Can you recommend warm 6sn7?
Thanks, i have managed to buy sophia with significant discount. I have ordered rca 6sn7, so will try. Is mullard 6080 warm? I have heard it is bright.
In my experience the WA22 is a good but not great headphone amp, that sounds much better as a preamp to another solid-state headphone and/or speaker amp. That's where it shines, as all it needs to do is provide pleasing euphonic distortion for another amp that does the heavy lifting for driving headphones. I think the output transformers may be the the weak link/reason for this, as they don't need to work as hard when used as a preamp as they do when driving an actual transducer load
