Joao Paulo Martins
- May 25, 2017
I'll keep ans eye there
If you have a noise floor, something is going on with your tubes, chain, or your particular setup. My WA22 is dead quiet with both low and high imp cans.Got the Gen 2 recently and am running 5998 Tung sol, 422A, Ken Rad Black Glass VT-231, Zu Audio Power/interconnects and audioquest power.
I'm not sure how the Gen 1 is with this setup but I'm replacing Linear Audio V2 w/ ps, and a ifi pro and this is definately much better.
Floor noise is okay as I think the gain on some of the tubes is a bit high.
Using Z1R, Elex, LCD4, LCD2. Sounds great with all, maybe a bit bright with the elex, elear should sound great.
I use the same power and driver tubes, just a different rectifier.
Yes, I run mine balanced (DAC > Pre > WA22 > Cans) since day 1 and never have any noise problems. Try swapping out your tubes and see.It may be one or more of my tubes making the noise, but I dont think so.
Are you using your cans with balanced? I find that If I use the balanced stereo out, I get more noise than the SE.
I finally got around to replacing my stock tubes with the following: Western Electric 422A rectifier, Western Electric 421A power and Sylvania 6SN7W Metal Base driver tubes. after being familiar with the stock tubes' sound for nearly 2 years, this new set of tubes was a stunning revelation to me, especially when listening to classical stuff like Ravi Shankar. I'm considering collecting driver tubes that may work well with this combo, for listening to jazz and rock. any input from you guys will be appreciated, thanks
For jazz and rock. Just swap in some kenrad vt 231 black glass and rock on.I finally got around to replacing my stock tubes with the following: Western Electric 422A rectifier, Western Electric 421A power and Sylvania 6SN7W Metal Base driver tubes. after being familiar with the stock tubes' sound for nearly 2 years, this new set of tubes was a stunning revelation to me, especially when listening to classical stuff like Ravi Shankar. I'm considering collecting driver tubes that may work well with this combo, for listening to jazz and rock. any input from you guys will be appreciated, thanks
