@LegionofDoom mentioned to me that his amp has a little bit of 60 Hz hum when music is paused. I have the same issue. It was present before I did the coupling cap mods, and it is there regardless of what tubes I’m using (I’ve replaced them all in multiple configurations, and it’s aways there. It’s not bothersome when listening to music, but I’m sure there would be a subtle improvement to detail and soundstage if this were corrected. Another quirk I’ve found is that it seems much more noticeable with low impedance headphones. A little digging online has me thinking it might be a result of DC coming through my mains. I stuck a multimeter in an outlet and I have about 58 mV of DC on the line, which might be too low to have an effect, but then again this is a very sensitive piece of gear, so perhaps…
Anyway, I was thinking of getting a filtering device. Pine Tree Audio makes custom linear power supplies and other esoteric electronics for audiophiles - they were recommended to me by Geno at Geshelli Labs when I was looking for a linear power supply for my soon-to-arrive Dayzee DAC. They have a power filter with a DC filter and AC noise filtering with fancy meters, etc. for $1,100, which seemed a little high to me for an uncertain possibility of fixing this one problem, so I am waiting to hear back from Jessie over there on a quote for a bare-bones version with all of the filtering, but a more basic case and no monitors, as well as a quote for straight up DC filter. I also saw this one, but I’m not ready to gamble this much $ for something I’m not sure will help…
https://upscaleaudio.com/products/i...sCCyS4wdoj1_u0hjbgZZd2m_cFn9OrgRoChxwQAvD_BwE
I’d be curious if anyone has any thoughts / insight on this. Either way, it’s sounding so good, I won’t be bothered if I can’t fix it. It’s in one of those spots right now with this tube set that I keep thinking of things to listen to, but I don’t even want to switch off the random tracks coming on after each song
