Did you try the latest version of Foobar? I'm running Windows 7 x64 with ASIO4ALL plugin and it works very well. Does your motherboard have an onboard soundcard? Maybe you can switch to that one just to see if the ASIO will work. That will at least isolate the problem. Good luck!
Originally Posted by fenixdown110 /img/forum/go_quote.gif You're the only one I've seen that thinks Win7 is a step back...
For me, for audio only, it was a step back.
It was great being able to get bitperfect without worry with the Auzentech Prelude. I got tired of the fighting for bitperfect in the past and was super happy when I found the Prelude could do it in all apps with no problems.
Perhaps I have to find a hardware solution that will accomplish the same thing in Windows 7.
Originally Posted by somestranger26 /img/forum/go_quote.gif 1. Zune is bitperfect for me on Windows 7 x64, as is foobar2000 if I use WASAPI or similar outputs. I don't mess with garbage like iTunes.
2. Everything that is played back through DirectSound will go to your default playback device. It will play simultaneously with anything you explicitly path, such as telling Foobar2000 to play over USB and having Winamp play over Toslink.
How did you get WASAPI working in Zune?
I've searched and I can't find any options to enable it in Zune or WMP.
Originally Posted by Negakinu /img/forum/go_quote.gif Did you try the latest version of Foobar? I'm running Windows 7 x64 with ASIO4ALL plugin and it works very well. Does your motherboard have an onboard soundcard? Maybe you can switch to that one just to see if the ASIO will work. That will at least isolate the problem. Good luck!
I should perhaps try ASIO4ALL and see if that gives me the option of selecting SPDIF, I haven't tried that in Foobar yet as WASAPI seems to work just fine and has the SPDIF option.
It is kind of cool that I can have WASAPI working in Foobar outputing a bitperfect digital stream, and have another application playing at the same time through the analog output.
Perhaps I should just spend some more time with Foobar on the interface and see if it is better than it used to be. I don't really have time to muck around with it though.
