Will order 555 or 595 today, HELP ME DECIDE!!!
Jul 11, 2006 at 9:43 PM Post #31 of 36
Originally Posted by sacd lover
If you try and wear the headphone pulled forward like most headphones you will have problems. If you wear them back the piece doesnt touch your ear. Moreover, if you look at the driver, its offset .... forward. To get the best alignment the headphone needs to be positioned back. The 595 is the most comfortable headphone I have ever used except for possibly the sony cd3000.
like RichardCory, i tried positioning my hd555's in everyway possible, and i could still feel the hard plastic thing. i don't have big ears either. the plastic piece isn't fatiguing, but it annoyed me just because i could feel it touching my ears. like i said in a previous post the hd555's are nowhere near as comfortable as the k701's or dt770's *to me* They were, however, WAY more comfortable than my sr60's
Jul 12, 2006 at 4:44 PM Post #32 of 36
Hi,
got the cans (50ohm) today!
i am satisfied with the sound, they sound clear and smooth.
the bass is quite strong. i am hearing the voices clearer and are hearing more details than before. Highly recommended.
Some pics i took:
http://img361.imageshack.us/my.php?i...10007280xs.jpg
http://img54.imageshack.us/my.php?image=p10007275fq.jpg
http://img287.imageshack.us/my.php?i...10007297mo.jpg
Jul 12, 2006 at 4:57 PM Post #33 of 36
Originally Posted by davve
Hi,
got the cans today!
Glad you like them! once you get used to the soundstage, you wont be able to listen to anything else.
Jul 12, 2006 at 5:39 PM Post #34 of 36
ordered them today, should get them tomorrow.
are you using the little dot 2 with the tubes?
with wich source have you connected the amp to?
Well, I got the Little dot 2 plus which is the upgraded version.
http://www.little-tube.com/forum/for...sp?TID=31&PN=1
My source is my PC with AV710 sound card, but I'm thinking to get a CDP,
I don't really like the player using up all the resource on my PC when I'm working on other stuff on my machine.....
Jul 12, 2006 at 5:55 PM Post #35 of 36
Ok, isn't an tube amp increase the distortion?
Jul 12, 2006 at 7:20 PM Post #36 of 36
I guess it's more or less depends on the quality than SS/tube.
The main difference of SS and tube is the sound you get.
For this amp, it's only <1%, so it doesn't make a difference for me.
And I like the sound better than straight from the card.
