Introducing higher amps to the Pro or Mini is not necessarily what is needed, but more about getting clean, low ripple & regulated DC power going into the pro. The problem is that these cheap switching power supplies are very susceptible to introducing dirty and unregulated power to the Pro.
"Switching power supplies are the entry point of external noise from other systems and also the exit point for releasing noise to the load (e.g., IC circuits). The switching power supply itself is also a source of noise. This noise does not only flow through power supply lines as conducted noise but also becomes radiated noise (harmful electromagnetic radiation)—which adversely affects itself and other electronic equipment."
It's best to use is a highly regulated linear AC-DC power supply feeding super clean and rock stable DC juice to the Pro or any other audio components requiring DC power, like most science equipment, research, aerospace and measuring components use LPS's. The problem is that they're expensive, big in size (physically) and inefficient (electricity-wise), A non-audiophile Acopian Gold "series A" LPS are excellent (very low Ripple mV RMS: 0.25) but need some finish work for home environment use.
I can confirm using a good battery source dramatically improves my usb reclocker SQ but also found the cheap 5v usb cell phone battery back-up packs on amazon do not, they were noisy due to the cheap & anemic electronic regulator & charging components inside them, So mileage may vary on what you use,
Personally, I can not yet confirm or know if the Wiim Pro or Mini will have a noticeable SQ improvement or Not when using a better PS than the stock one. But as quoted above, the typical cheaply made china $2-ish SMPS (wall wart) power supplies that are included in a lot of audio components can really effect SQ and performance of the component. That's what's so great about the DIY Audio DC filter kit (
DIY Store & thread), it can be a cheap solution, it's small, it's efficient and cleans up to stabilize and helps filter out noise or dirty juice coming out of your wall wart before going into the component (Wiim). DC juice with Ripple is not your friend and you want get rid as much ripple as possible. A highly regulated, low ripple, properly filtered stage will also most likely help reduce any jitter being produced in the Wiim and help the components inside the Wiim work at max potential of their design and help keep them from puttering.
It's like giving your car high quality, high octane gas.
