Those cables I suggested will work. I have those and I also have an iFi micro iDSD. If you want a SPDIF to micro tossing adapter for a toslink cable you may have here it is.Thank you, but the Neo dac has a coaxial input. I rather think of an adapter kind of toslink female to coaxial male.
WiiM Streamers Mini and Pro
- Thread starter Ufanco
I think that is what they mean - fixed volume when they say "fixed line-level".It's a bit confusing because in the manual it says to achieve bit perfect output, you need to use the digital output and the "fixed line-out level". Now, what the heck do they mean by fixed line-out level? I don't think it's the same as fixed volume level, but who knows? It does, however, make sense that the only reason for the internal DAC is for either outputting or inputting analog signals to or from the unit.
To be honest, I'm not to hung up on the semantics, because it sounds fantastic, or maybe the proper phrase would be, that it passes digital audio perfectly without imparting any distortions or artifacts : )
Hmmmmm............ I don't think that's true. I was under the impression that the WiiM's internal DAC was only used when outputting audio to the WiiM LINE OUT jacks (or inputting from an external device into the Line Inputs of the WiiM), and while I do have the volume on my WiiM Pro set to FIXED, I do use the EQ set to ON, and I'm getting bit perfect digital input into my Topping D30Pro DAC connected via digital coax, but please do correct me if I'm wrong.
Guess I need to look into it more. I could me wrong concerning it being bit perfect well using the EQ. I thought I read that both volume and EQ effected the bit perfect output.
I also thought If you are EQ'ing, you are modifying the streaming going into the DAC, therefore, it's not bit-perfect?
EQ definitely changes the data (bits).Guess I need to look into it more. I could me wrong concerning it being bit perfect well using the EQ. I thought I read that both volume and EQ effected the bit perfect output.
brantome
It needs to be fixed volume and EQ off to be bit perfect. Even with EQ on and set at flat, there’s a change in the bitstream (and reportedly some distortion) so it’s no longer bit perfect. Whether you could hear that is an entirely separate argumentEQ definitely changes the data (bits).
Derek Dean
Well, you've got me wondering now..... I think it should be easy enough to get a definitive answer directly from the folks at WiiM.
It does in fact loose it’s bit perfect. You could put an analog eq like Bellari eq 570 between the dac and amp to suit your needs.Well, you've got me wondering now..... I think it should be easy enough to get a definitive answer directly from the folks at WiiM.
Derek Dean
Maybe I'm simply confusing terminology here. Of course, when you use the EQ, your changing the sound, so I guess the bits going out are different from the bits coming into the WiiM, but, it doesn't appear to be changing the bit depth or resolution, so if it comes in as a 24/192 and goes through the EQ, then it will still go out as a 24/192 file, just with the sound changed (which is why we use the EQ, to change the sound).It does in fact loose it’s bit perfect. You could put an analog eq like Bellari eq 570 between the dac and amp to suit your needs.
I had originally been thinking that wanting bit perfect meant getting files to go through the WiiM without changing the bit depth and resolution, but if it means with no change to the sound at all, them I'm fine with it not being bit perfect, because I really like how the WiiM EQ helps me get the sound to where I need it, bit perfect or not, as long I'm still getting the same bit depth and resolution as the original file.
In any case, I've submitted the question to the folks at WiiM and will report back what they have to say.
brantome
I’m sure Wiim have said so on several occasions on other forums like their own community forum and audiosciencereview. Here are a couple of links from their faq that touch on such https://faq-mini.wiimhome.com/support/solutions/articles/72000594355-which-eq-setting-should-i-use- and https://faq-mini.wiimhome.com/support/solutions/articles/72000593467-setting-volume-controlsWell, you've got me wondering now..... I think it should be easy enough to get a definitive answer directly from the folks at WiiM.
Derek Dean
Funny, I spent quite a while over on their forum and FAQ area, but didn't see that one. Yes, that was helpful, thanks : )I’m sure Wiim have said so on several occasions on other forums like their own community forum and audiosciencereview. Here are a couple of links from their faq that touch on such https://faq-mini.wiimhome.com/support/solutions/articles/72000594355-which-eq-setting-should-i-use- and https://faq-mini.wiimhome.com/support/solutions/articles/72000593467-setting-volume-controls
Indeed, no matter what other people say as long you’re happy on what you’re hearing it’s all matters.Maybe I'm simply confusing terminology here. Of course, when you use the EQ, your changing the sound, so I guess the bits going out are different from the bits coming into the WiiM, but, it doesn't appear to be changing the bit depth or resolution, so if it comes in as a 24/192 and goes through the EQ, then it will still go out as a 24/192 file, just with the sound changed (which is why we use the EQ, to change the sound).
Derek Dean
Yes, indeed, but at the same time, I'm sincerely interested in learning about what's going on inside the WiiM, and more importantly, I certainly don't want to pass along misinformation to others.Indeed, no matter what other people say as long you’re happy on what you’re hearing it’s all matters.
So, now I understand why some folks prefer the absolutely no EQ path, wanting as pure a signal (bit perfect) as possible. I get that. It's a choice of no EQ with bit perfect reproduction, or have EQ with the possibility of some added artifacts (whether audible or not). Very interesting stuff. In any case, it is nice to know that with the right settings, the WiiM is capable of passing bit perfect audio, then it's simply up to the user to decide which option works best for them. Thanks everybody for a very educational afternoon.
There are two wiim, mini and pro both used same based code but mainly the difference are features. Pro has coax, spdif, Ethernet and more importantly it has more power hardware from mini dual core to quad core from pro to 128 memory to 512 memory from pro. It will have a long life span on adding features than mini.Yes, indeed, but at the same time, I'm sincerely interested in learning about what's going on inside the WiiM, and more importantly, I certainly don't want to pass along misinformation to others.
Ferdinando1968
I use the WIIM connected in SPDIF to the IFI Gryphon.
If I enable EQ, MQA decoding stops working.
Can anyone confirm having the same behavior?
