KU1185,
The Audio-GD R28 (R2R DAC-analog preamp) has been sounding great, very happy with it and anything I've recently put against it gives me zero reason for wanting something else; except for the Aqua La Scala but that needs a preamp & more $$$. I can confirm it does sound better (in my system) than the top of the line Burson Conductor 3X GT, and the Burson Conductor 3X Reference and the RME ADI-2 DAC (non-pro). Audio-GD just sounds better, bigger and fuller sound, darker background and more musical than the others, definitely more even from top to bottom.
Thanks for the PS tip for the Wiim Pro, that's good info. I too have found big SQ improvements in other components when replacing or upgrading the cheap switching power supply wall wart, wasn't sure if it mattered with the Wiim. I think I have a Keces 5V linear power supply laying around and a very cool Dick Sequerra Power Station- PS1 (linear power & battery power) that I restored & modified with a new 12ah battery and updated cables, I think that could work really well for the Wiim.
It will be interesting to hear from others if you hear any improvements in the Wiim SQ (Maybe, Maybe not) with any tweaks or improved PS?
I have a Wyred4Sound USB reclocker powered by a Li-ion battery pack and that makes a massive difference, it's a night & day SQ improvement, there's no contest between the two and battery makes it worth the hassle, best tweak ever and threw its wall wart in the trash after comparing.
You guys might also want to check this cool and inexpensive PS mod kit on DIY Audio (50 page thread) for really improving/cleaning up the noisy power coming out a cheap DC wall wart. This looks like a perfect mod/kit to use on the Wiim Pro's wall wart. Just requires some very basic soldering skills to do and it's very cheap to do and even Nelson Pass gave it a thumbs up.
https://www.diyaudio.com/community/...all-warts-preamps-hpa-korg-nutube-etc.354213/
My Wiim Pro will be used with the digital out to Audio-GD R28 via coax, will also try the RJ45 network input from a UpTone EtherREGEN or maybe wifi is better? We shall see.
Very much looking forward to hearing from others on any improvements (or not) when playing around with there Wiim Pro?
