Originally Posted by Teerdz /img/forum/go_quote.gif If you read the post and search a bit. Little Dot MKIII is 199 dollars. And the Nuforce uDac is 99 dollars. 300$ + 30-50 for delivery.
is there any alternative for the amp? since i dont think my table with the mess can fit the size of tube amp. im looking for those with square box shape so i can just put it nicely under my monitor.
p/s website for Little-Dot MKIII is www.little-tube.com right? i have "Server not found" with that address.
Originally Posted by sterob /img/forum/go_quote.gif p/s website for Little-Dot MKIII is www.little-tube.com right? i have "Server not found" with that address.
Hi, I'm new here and looking for a similar item for my AKG 702's. Here is the link I found for Little dot. It looks like a forum but has all the specs for each item. Hopefully it's the right site.
Originally Posted by rprokop63 /img/forum/go_quote.gif Hi, I'm new here and looking for a similar item for my AKG 702's. Here is the link I found for Little dot. It looks like a forum but has all the specs for each item. Hopefully it's the right site.
The first amp I heard that does the HD650 justice is the Darkvoice 337. Save some more money if you can, and simply just cut to the chase ($480 + $135 USD shipping). . . . then you will need a worthy source. : )
Putting an amplifier under a monitor is not a good idea since amplifiers by nature get WARM. Trapping most of their ability to emit heat can lead to overheating and internal damage.
