Ruben123
- May 17, 2012
Idk about those imd etc but you sure need a microphone that records those ultrasounds and well many microphones don't actually do that AFAIK
The post I responded to suggested that no musical instrument produces frequencies even near 20 kHz.
That is simple not true.
Frequencies above the upper treshold of our hearing we cannot hear by definition.
But content above this threshold can generate IMD that maps into out audible range.
But does it affect the frequencies within the audible range? Possibly yes but probably, maybe not.
[1] Also there are a lot of energy sources but how much are them mechanic? Due to natural selection, our body is very capable of perceiving mechanical energy only if it has enough power. Unlike electromagnetic energy, we really do not need any specific receptors to perceive mechanical energy because almost our entire body is somehow capable of interpreting mechanical stress (if they have enough power).
[2] Beyond this point, scientific works needed.
[3] Considering low levels of ultrasound found in music files due to cropping, bad(?) mastering(?), (I think) It would be impossible to perceive them even indirect form.
[4] If you take hand skin (where energy reflects to epidermal hand cells), yes it needs big magnitude. But ear is very complex organ and there are different type of cells at where stereocilia located. Maybe these cells need less power than hand cells to notice it to brain via neurons?
[5] But I think it like this: When you listen extreme bassy musics, you think like your brain is shaking (maybe not correct term but you got the point). That "shaking feeling" is not audio but it is a intended thing to experience while listening music. Because music makers got that feeling too.
Originally Posted by Asuhra /img/forum/go_quote.gif
[1] At 48Khz you have much more headroom to put info between the 15.5 and 20Khz Freq range when doing subliminals (it's a mathematical thing).
[2] It has been proven by dog trainers that you can hear at least up to 30Khz because they got affected by the subliminals meant for their dogs @ 30Khz range. [2a] I have proven that on myself time and time again.
[3] As for the resolution, that has also been proven that some people notice differences up till 96Khz.
[1] Crash cymbals can go far in excess of 20 kHz ...
[2] Actually most condenser mics do. They may have drooping response.
If the recorded instrument is creating IMD that impacts the audible range, it is already being captured with a typical recording microphone. The only thing to consider is if the actual ultrasounds are making any kind of difference for the listener, because any audible influence should already be present in the recording.
Scientific evidence is rare but this survey by Pras indicates that people are able to discriminate between 44 and 88. This is only the case with an orchestral recording.
Maybe because of the IMD? http://www.academia.edu/441305/Sampling_Rate_Discrimination_44.1_KHz_Vs._88.2_KHz
(scroll down a little)
I haven't had time to go through it in fine detail but there are a few things I noticed:
1. Only 3 of the 16 participants demonstrated any ability to differentiate with a significance better than chance/guessing.
2. If I read correctly, although there was significance in the results of those 3, they were actually wrong. They thought the 44.1kHz recording was the higher res version!
3. To be sure one is actually testing what one is aiming to test, all variables other than the variable being tested need to be eliminated. This is considerably more difficult that it usually appears! In this study, the ADC's internal clock was used for the 44.1kHz recording while an external clock was used for the 88.1kHz recording. I'm not sure why they did this, external clocking usually adds jitter to the system. This could explain why the 44.1kHz recording was thought by the 3 to be the higher res version, although with most modern, high quality ADCs the level of additional jitter from external clocking should not normally be audible. This is still a variable which should have been eliminated though, as was using such different recorders.
4. I didn't see where they explained their methodology for down-sampling. Certainly it was fairly common a few years ago that re-sampling software would reduce amplitude of the signal (to eliminate illegal intersample peaks at the high sample rates used for conversion). Generally the reduction was only about 0.2dB or so and most would not detect any difference, a trained listener, with certain types of audio material and certain listening environments might be able to. Volume matching is another variable which is more difficult in practice to eliminate than it may seem to be.
5. Yes, I agree, IMD is another potential variable which I'm not sure was eliminated.
G
... provided I'm reading the data correctly ...
Who is ignoring science? There is no thing as ignoring science. If you don't believe gravity there is no gravity?
Can you post scientific materials or your opinions instead of arguing?
it could depend on the EQ you're applying. admittedly if you end up with some freqs real close to 0db or even slightly clipped, then mp3 could have some/more clipping than the flac file. and of course that can be more audible. that due to intersample clipping. if the signal is consistently at a good -3db, then you would avoid that problem IMO.
some nice peak meter could show that(and they will by oversampling, so that the peaks are closer to the real peaks). if you can get your problem/difference while no peak meter can show potential clipping, then I'd be curious to see a short sample of the 2 versions.
otherwise, usually DSPs that really benefit from oversampling will just do so and then downsample back to whatever you originally used on the fly.
