Why would 24 bit / 192 khz flac sound any better than 16 bit / 44.1 khz flac if both are lossless (if at all)?
Mar 22, 2014 at 12:10 PM Post #136 of 391
Well, with dithering (the simple +/-1 LSB TPDF type), I can subtract the quantized signal from its original version, and the difference (the quantization error) sounds and looks (in a spectrum analyzer) like white noise at a constant RMS level no matter what the input signal is. This is easy to verify in practice
If the signal has sufficiently large variance, then quantization noise looses correlation to the input signal, including the non-dithered quantization. Are you referring to non-shaped TPDF generating white noise?
Mar 22, 2014 at 12:30 PM Post #137 of 391
Which is probably why it was posted. It is a common tactic by audiophiles to try to confuse people with walls of information, and use the "audio is infinitely complex and you do not understand it" argument to justify believing in whatever they want.
It was posted for educational purposes. And yes, audio is pretty complex. That's why we are still finding new ways to make improvements in this field.
Mar 22, 2014 at 9:13 PM Post #138 of 391
Can anyone explain why my 24bit Vinyl downloads have a much lower play volume compared to my 16bit?
The two files I'm comparing are the exact same song with the following specifications:
24bit:
Sample rate: 96khz
Avg. Bitrate: 2761 kbps
VS.
16bit:
Sample rate: 44.1khz
Avg. Bitrate:  925kbps
The problem persists when played through Windows Media Player, VLC, and Winamp.
Mar 22, 2014 at 10:32 PM Post #139 of 391
24bit:
Sample rate: 96khz
VS.
16bit:
Is your 16-bit one a vinyl rip too?
Mar 23, 2014 at 3:19 PM Post #142 of 391
This is very easy to uderstand in practice. Because the DR is higher for a 24bit depth sample. Since you have much more headroom available.
Mar 23, 2014 at 3:37 PM Post #145 of 391
  If both formats are lossless, what differentiates the 2 versions in terms of sound quality if at all?
Why does 24 bit / 192 khz flac sound any better than 16 bit / 44.1 khz flac if both are lossless ?
Difference come from the quality of headphones, and the quality of music player (source).
sam
Mar 24, 2014 at 1:38 PM Post #146 of 391
Except, they're not really improvements if they're inaudible. The threshold of audibility in digital to analog conversion was probably passed 30+ years ago. Now, AAC might be a little better than mp3 at the same bitrate, but they're both pretty transparent at 256kbps+. Is anyone aware of a large scale study comparing mp3/AAC to lossless or CD quality?
Mar 25, 2014 at 2:28 PM Post #147 of 391
sam
which TOTALLY makes sense if he's using the same gear for them both.
The way I get my head around thinking of this is as being rather similar to video in the way moving images are better at higher FPS than at lower frame rates.
There's no loss of DATA in each single frame, but faster rates make the moving image more coherent.
Simplistic, but it kind of makes it more understandable to me.
Mar 25, 2014 at 5:58 PM Post #148 of 391
But this analogy fails because our eyes can actually process the extra frames in video, whereas our ears can't hear the higher frequencies that a higher sampling rate can provide.
Mar 25, 2014 at 6:13 PM Post #149 of 391
Yet supposedly we shouldn't be able to see a difference between 60hz and 120hz screens but the difference is clear.
Mar 25, 2014 at 6:19 PM Post #150 of 391
yes.
which is why I said "simplistic".
I don't think it's just about pitch, though, is it?
Isn't it about richness too?
Help us out.
Can you give amore apropos way of thinking about it?
Not being challenging, just trying to grip this issue myself.
I take those tests...and I can generally tell the diff. about 90%, most days.
probly 'cuz I live with dogs.
they've taught me all the tricks.
:cool:
