Akathriel
- Oct 11, 2005
There is one other reason, to use 2x3 pin. Correct me if Im wrong but if your headphone cable is shielded, you could connect the drain wire to the ground of the amp.
Originally Posted by TreAdidas /img/forum/go_quote.gif According to Headroom's Tyll at the LA and Orange County Audio Society Meet. They made the first balanced headphone amplifier and the reason they used the XLR type connectors was because Neutrik makes a combo 3-pin XLR and 1/4" plug chassis jack. That makes it convenient to do both balanced and single ended in just two chassis points. From http://www.neutrik.com/us/en/lightin...oductlist.aspx "First XLR / jack hybrid panel mount connector combining a 3 pole XLR receptacle and mono or stereo ¼" phone jack in one XLR housing." |
Originally Posted by MaloS /img/forum/go_quote.gif Ya but we tend to connect our system before we even turn it on so that does not really matter. |
Also TRS is fairly standard in quite a bit of professional systems I've seen. Generally more comfortable >.< I get constantly bothered by how big XLR is, when electronically having pair of mini-plugs is as good as pair of 3-pin XLRs..hell, a pair of mono mini-plugs is just as functional (you only need in and out pins, which can be easily substituted by + and ground points of a mono mini-plug). |
Originally Posted by Sovkiller /img/forum/go_quote.gif IIRC the 1/4 plug inside the XLR is mono |
Originally Posted by swt61 /img/forum/go_quote.gif Nice solution grawk. |
Originally Posted by krmathis /img/forum/go_quote.gif You talk about balanced signal between source and amplifier, right? Then XLR is used because there are three cables to connect. * Chassis ground (cable shield) * Normal polarity ("hot") * Inverted polarity ("cold") http://en.wikipedia.org/wiki/Balanced_audio http://en.wikipedia.org/wiki/XLR |
Originally Posted by mofonyx /img/forum/go_quote.gif I agree with krmathis. The third pin is wired to the cable shield. |
