Xakepa
- Sep 2, 2005
Pls, read the second sentence of my post. It's the brain that sets the limit, and once the psycho-acoustic model "gets" how brain discards info, you're done. You could increase fidelity, bandwidth etc but you won't be able to percieve that.
Originally Posted by Skylab This isn't an apples-to-apples comparison, and in any case completely misses the point. It's true that there is additional resolution in a 24 bit (versus a 16 bit) recording, and this may yield slightly better sound, but the dynamic range of a 16 bit recording (which is what bit depth effects) is already impressively good. And yes, 96 or 192 kHz sampling will extend frequency response, which some people *may* bea ble to hear. BUT - lossy codecs do not work by changing bit depth of sampling rate. They are, as most know, based on pshyco-acoustical algorithms which actually remove data that is WELL WITHIN THE RANGE OF HUMAN HEARING. True, in most modern lossy codecs this removal of sound is imperceptible, but it is NOT the same as changing bit depth or data rate at all. So your argument does not hold water. I'm not arguing that people should listen to lossless -- that is up to the individual. But when you rip, you should rip in Lossless. Anyone who tries to claim otherwise is just making themselves feel better about having spent time and effort ripping CDs in a sub-optimal way. And also, there is nothing "uber-elitist" about this -- it's quite the opposite, it's about utility and flexibility. If you ripped in MP3 320k, it may sound perfect to you. But if you them want to transcode to AAC 192 for some reason later, you will SERIOUSLY compromise the sound quality, whereas if you had ripped in lossless, this would be no problem. |
